[QGIS-Developer] Other Grass Processing issues
matteo matteo.ghetta at gmail.com
Wed Apr 18 05:07:58 PDT 2018
Hi all,
sorry for bombing the mailing list, but I've some time to test Processing.
It seems that some (many?) GRASS algorithms are not correctly working.
What I discover is that whenever a numerical column is needed the
algorithm fails (v.surf.idw, v.to.rast).
I tested with different datasets and different column typee (integer,
real..) but the error is always similar, a small extract of the log:
v.external complete. Link to vector map <vector_5ad734cddf0ce4> created.
WARNING: Missing key column name
ERROR: Column <LABEL_ANG> not found
ERROR: Raster map <output0a1efa7bd4864096917ddaf7bb885b79> not found
ERROR: Raster map or group <output0a1efa7bd4864096917ddaf7bb885b79> not
found
anybody else has faced this problems?
Thanks and sorry again for bombing
Cheers
Matteo
More information about the QGIS-Developer mailing list
