[QGIS-Developer] Legend layer customization missing
delazj at gmail.com
delazj at gmail.com
Sat Apr 21 08:09:15 PDT 2018
Hi Régis,
I do not have QGIS to test but i also had issues with the capitalization part. Reported at https://issues.qgis.org/issues/18574
Regards,
HarrissouLe 21 avr. 2018 4:45 PM, Régis Haubourg <regis.haubourg at gmail.com> a écrit :
> Hi, I just tested forcing the layer groups to bold using advanced settings, but it doesn't apply. Someone confirms?
> Regards
> Régis
> Le sam. 21 avr. 2018 à 11:10, matteo <matteo.ghetta at gmail.com> a écrit :
>> HI Nyall,
>> > This option was dropped. The rationale was that we cannot have options
>> > for every user interface setting like this or the interface becomes
>> > just a daunting mess! Either bold names is good, and they should be
>> > used in all installs, or they aren't needed.
>> >> , capitalize...)
>> > This is a bit controversial - during 3.0 development the setting was
>> > made default for a while, and the option dropped. But there was
>> > push-back after this and the on-by-default change was reverted, and
>> > the setting was moved to the advanced settings page only.
>> I perfectly understand the need to avoid every user case options..
>> still wondering if this options can be added only in the advanced
>> settings dialog (so there it should not result in a messed up UI). But
>> as said, I don't know if this can bring to coding issues.
>> Thanks for the clarification!
>> Cheers
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
