[QGIS-Developer] R provider for QGIS 3 - any interest?
Barry Rowlingson b.rowlingson at lancaster.ac.uk
Thu Apr 26 05:10:09 PDT 2018
As a long-time R spatial developer and QGIS user I'll be glad to help out -
but time-poor at work for now. "Helping out" may be more  like "making
unreasonable suggestions" and "finding annoying bugs".
For example, can we find a more efficient way to transfer data from QGIS to
R? Can the new `sf` packages in R work with the data straight out of QGIS'
memory? I *think* the `sf` package stores vector data in GDALs native C++
objects, and if QGIS is doing that too then we *might* be able to get
access from QGIS and R if we write the R plugin as a C/C++ module that
dynamically links with the shareable libR.so.
The current R processing plugin  converts QGIS layers to shapefiles, reads
them into a new R process. On occasion I've hit problems with shapefile
limitations (field name length, usually) that make my scripts fail. Maybe
it should go via geopackage instead.
Should it create `sp` objects on the R side or `sf` objects? This could be
controllable in the R processing script headers, so it can be set on a
per-script basis.
I'll stop now...
Barry
On Thu, Apr 26, 2018 at 9:42 AM, Aurelio Pires <anvpires at gmail.com> wrote:
> +1
> Thanks,
> On 2018-04-26 07:40, Paolo Cavallini wrote:
> > Hi all,
> > Il 26/04/2018 05:08, Nyall Dawson ha scritto:
> >> I'm VERY interested in seeing this resurrected. I'm available to
> >> mentor this task if someone else wants to take ownership of the plugin
> >> and do the port, OR alternatively I'd be happy for North Road to do
> >> the porting ourselves and take over maintenance if someone can fund
> >> this work.
> > that's good news. So starting a crowdfunding campaign seems a good way
> > to go, unless there is a bigger sponsor; do you agree?
> > All the best, and thanks.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180426/335b0d2b/attachment.html>
More information about the QGIS-Developer mailing list
