[QGIS-Developer] Question on FGDB support for "Save As" / "Export"
Alexander Bruy
alexander.bruy at gmail.com
Thu Aug 2 02:42:16 PDT 2018
чт, 2 серп. 2018 о 12:35 Nyall Dawson <nyall.dawson at gmail.com> пише:
> I'm not sure how this change would need to be made though. At the
> moment if you install the closed driver in osgeo4w it's always used,
> for both reading and writing layers. Even/Jürgen is this an osgeo4w
> thing or a GDAL thing? Is it possible to have two drivers installed
> for the one format and always read using the closed driver?
AFAIK, you can select which driver to use with envronment variable.
> Another complication is that we'd still need a way for users to opt in
> to using the closed driver for reading - as that may sometimes be
> required too... So not a straightforward change, but still one that
> I'd support!
As I understand, we need something like existing rasters drivers list
in the QGIS setttings where one can choose which drivers should be
used. There is already ticket about this https://issues.qgis.org/issues/10313
Alexander Bruy
