[QGIS-Developer] Plugins translation
Jorge Almerio
jorgealmerio at yahoo.com.br
Tue Aug 7 09:25:47 PDT 2018
Hi devs,
For do the plugin translations I use
1) Linguist from QT5
2) The command line:
Pylupdate4 -noobsolete PluginName.pro (Is there a new version 5??)
3) and the classical code:
# initialize locale
locale = QSettings().value('locale/userLocale')[0:2]
locale_path = os.path.join(
self.plugin_dir,
'i18n',
'PluginName_{}.qm'.format(locale))
if os.path.exists(locale_path):
self.translator = QTranslator()
self.translator.load(locale_path)
if qVersion() > '4.3.3':
QCoreApplication.installTranslator(self.translator)
def tr(self, message):
return QCoreApplication.translate(QWaterPlugin.SETTINGS, message)
The problem is that the option to use self.tr('message string') is not working. It only works when I use QCoreApplication.translate('Escope', 'message string') even if a tr function defined.
It used to work with linguist from QT4.
What Am I doing wrong? BTW Is there a new better way to translate plugins?
Another thing, every time I update the translations strings with Pylupdate4, I have to translate all my plugin forms again even without any changes, any help???
Thanks,
Jorge Almerio
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180807/411d94bd/attachment.html>
