[QGIS-Developer] GRASS r.kappa not working in QGIS plugin
Nyall Dawson
nyall.dawson at gmail.com
Wed Aug 8 23:40:22 PDT 2018
On Mon, 6 Aug 2018 at 17:38, Sophie Crommelinck
<sophie.crommelinck at gmail.com> wrote:
> I just noted that everything works fine, when the module r.kappa is run once manually via the toolbox in QGIS before running the plugin. When I open QGIS (I am using the latest QGIS 3.3.0 nightly build version) and run the plugin directly, the GRASS module r.kappa in the plugin doesn't work. When I open QGIS, run r.kappa via the toolbox and run the plugin then, the GRASS module r.kappa in the plugin works fine. Not sure how to fix this.
> Best,
> Sophie
> On Mon, 6 Aug 2018 at 08:10, Sophie Crommelinck <sophie.crommelinck at gmail.com> wrote:
>> Hello,
>> I am working on a QGIS plugin, that should use the module r.kappa from GRASS. It looks like this in my plugin source code:
>> processing.run('grass7:r.kappa',
>> {"classification": classificationLayer,
>> "reference": referenceLayer,
>> "title": 'ACCURACY ASSESSMENT',
>> "-h": False,
>> "-w": False,
>> "GRASS_REGION_CELLSIZE_PARAMETER": cellSize,
>> "GRASS_REGION_PARAMETER": None,
>> "output": outputFile})
>> As an error, I get a QgsProcessingException saying 'There were errors executing the algorithm'.
Can you try putting somewhere near the start of your script:
from processing.algs.grass7.Grass7Utils import Grass7Utils
assert Grass7Utils.installedVersion()
And see if the assert passes, and whether that fixes your issue?
Nyall
