[QGIS-Developer] Running grass algorithms in threads
Nyall Dawson
nyall.dawson at gmail.com
Tue Aug 14 16:10:14 PDT 2018
On Tue, 14 Aug 2018 at 21:43, Rudi von Staden <rudivs at gmail.com> wrote:
> Hi all,
> The bottleneck in my script at the moment is the calculation of zonal stats using 'grass7:r.stats.zonal'. I thought I might speed things up by using QgsTask.fromFunction() or QgsProcessingAlgRunnerTask() to run these calculations in parallel. In my tests of both approaches the tasks seem to complete (task.status() == QgsTask.Complete), but the output file is only generated for 1 of 4 parallel tasks (the task that finishes first).
> I'm assuming this is because grass algorithms are not thread safe? Or am I missing something in my implementation that could make this work?
I strongly suspect that grass algorithms cannot be run in parallel.
This is why they cannot run in the background in QGIS like the
native/GDAL algorithms can. But I'd love for confirmation about this
and whether there's any way to make GRASS multi-thread safe.
Because this is grass related (and not QGIS specific) I'd suggest
asking on the grass mailing list, and relaying any responses back
here.
Nyall
> Thanks,
> Rudi
> My code for the QgsTask approach is as below:
> def getZonal(task, habitatModelFile, cover):
> tempFile = QgsProcessingUtils.generateTempFilename("output.tif")
> processing.run("grass7:r.stats.zonal", {
> 'base':habitatModelFile,
> 'cover':cover,
> 'method':5,
> '-c':False,
> '-r':False,
> 'output':tempFile,
> 'GRASS_REGION_PARAMETER':None,
> 'GRASS_REGION_CELLSIZE_PARAMETER':0,
> 'GRASS_RASTER_FORMAT_OPT':'',
> 'GRASS_RASTER_FORMAT_META':''},context=context,feedback=algFeedback)
> if task.isCanceled():
> deleteFile(tempFile)
> return
> return tempFile
> ls90Task = QgsTask.fromFunction('LS90', getZonal, habitatModelFile=hm1, cover=ls90Layer)
> QgsApplication.taskManager().addTask(ls90Task)
> feedback.pushInfo("Calculating LS14 mean...")
> ls14Task = QgsTask.fromFunction('LS14 ', getZonal, habitatModelFile=hm2, cover=ls14Layer)
> QgsApplication.taskManager().addTask(ls14Task)
> hs90Task = QgsTask.fromFunction('HS90 ', getZonal, habitatModelFile=hm3, cover=hs90Layer)
> QgsApplication.taskManager().addTask(hs90Task)
> hs14Task = QgsTask.fromFunction('HS14 ', getZonal, habitatModelFile=hm4, cover=hs14Layer)
> QgsApplication.taskManager().addTask(hs14Task)
> while (len([t for t in [ls90Task.status(), ls14Task.status(), hs90Task.status(),
> hs14Task.status()] if t in [QgsTask.Running, QgsTask.Queued]]) > 0)
> and not feedback.isCanceled():
> sleep(1)
> if feedback.isCanceled():
> # some cleanup code (send task.cancel() and wait for tasks to terminate)
> break
> ls90Result = ls90Task.returned_values
> ls14Result = ls14Task.returned_values
> hs90Result = hs90Task.returned_values # only this file exists
> hs14Result = hs14Task.returned_values
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
