[QGIS-Developer] [Plugin] Add help html documentation
Raymond Nijssen
r.nijssen at terglobo.nl
Wed Aug 22 06:09:27 PDT 2018
Hi Joao,
I used it in a qgis2 plugin:
# import it:
from qgis.utils import showPluginHelp
# create help function
def showHelp(self):
"""Reacts on help button"""
showPluginHelp(filename = 'help/index')
# connect it to some button (here in the old way):
QObject.connect(self.dlg.help_pushButton, SIGNAL("clicked()"),
self.showHelp)
It is here:
https://github.com/opengeogroep/AERIUS-QGIS-plugins/blob/master/ImaerReader/imaer_reader.py
Regards,
Raymond
On 22-08-18 14:51, João Gaspar wrote:
> Hi devs,
> I'm using the sphinx to help documentation to a plugin. I saw in QGIS
> documentation that we can add documentation using the function
> showPluginHelp().
> Where i can put the function showPluginHelp() in the plugin.py file?
> Regards
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
The Netherlands
+31 (0) 6 25 31 49 83
