[QGIS-Developer] Can't install QGIS after compile because of contributors.json
Andreas Neumann
a.neumann at carto.net
Mon Aug 27 10:58:56 PDT 2018
Thanks - then I wait for Tim to merge this into master.
Eager to try out the new easter eggs ;-)
Greetings,
Andreas
Am 27.08.2018 um 19:45 schrieb Etienne Trimaille:
> There is a PR to fix it from Mathieu:
> https://github.com/qgis/QGIS/pull/7722
> Le lun. 27 août 2018 à 13:05, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> a écrit :
> Hi,
> After compiling QGIS I can't install QGIS. When i run "ninja
> install" I
> get the following error message:
> CMake Error at doc/cmake_install.cmake:41 (file):
> file INSTALL cannot find "/home/an/dev/QGIS/doc/contributors.json".
> Call Stack (most recent call first):
> cmake_install.cmake:58 (include)
> FAILED: CMakeFiles/install.util
> cd /home/an/dev/QGIS/build && /usr/bin/cmake -P cmake_install.cmake
> ninja: build stopped: subcommand failed.
> Seems like the download/update/install of the contributors.json
> doesn't
> work?
> Thanks for any hints on how to fix this!
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180827/fedb58c1/attachment.html>
