[QGIS-Developer] HiRe: RES: Do we really need experimental and non-experimental plugins?
Borys Jurgiel
lists at borysjurgiel.pl
Mon Aug 27 13:29:36 PDT 2018
Thanks for all your answers. It clearly seems there is no common demand to
drop it ;) Frankly speaking, I didn't expect it's considered so useful.
Especially thanks to Martin and Paolo for explaining your use cases.
I'm also against restricting the time to be experimental - to keep this
function as simple and unambiguous as possible.
Best regards,
Borys
HiDnia poniedziaĆek, 27 sierpnia 2018 15:38:03 CEST Jorge Almerio pisze:
> Hi devs,
> I agree with Andreas. I think we need experimental and non-experimental
> flags to plugins as it is. And I think that we can NOT restrict the time to
> be experimental. Because it depends on the author available time to make
> his plugin stable. Restrict the experimental plugins would reduce the
> number of plugins been uploaded. To mark as experimental is important for
> the users and for the authors too, because one can help the other to fix
> bugs.
> Jorge Almerio
> -----Mensagem original-----
> De: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Em nome
> de Andreas Neumann Enviada em: segunda-feira, 27 de agosto de 2018 09:42
> Para: qgis-developer at lists.osgeo.org
> Assunto: Re: [QGIS-Developer] Do we really need experimental and
> Hi Borys,
> Personally, I think there is a need for the differentiation of
> experimental or not experimental.
> I'd like to keep it as it is.
> Andreas
> Am 27.08.2018 um 02:06 schrieb Nyall Dawson:
> > On Mon, 27 Aug 2018 at 04:11, Borys Jurgiel <lists at borysjurgiel.pl> wrote:
> >> Hi Lists,
> >> Before I make a QEP I'd like to know your general thoughts.
> >> After I removed the deprecated plugins filter from the Plugin manager
> >> (and
> >> make them always visible) [1], Alex suggested doing the same with the
> >> Experimental status.
> > I'm -1 on this. Experimental plugins can be dangerous (some result in
> > crashes, data corruption, etc), and shouldn't be shown by default.
> >> However, I'm not sure if it makes much sense nowadays. Releasing 'stable'
> >> and 'experimental' versions seems a bit overscaled to me. And there is a
> >> simpler solution: If the recent version is buggy, users can just
> >> download the last working one from the repo and install from zip.
> > I think that's overestimating some of our user's abilities -- it would
> > take a lot of knowledge that:
> > 1. a plugin is at fault
> > 2. they can overwrite a plugin manually with an earlier version
> > and
> > 3. they can download earlier versions of plugins.
> > Then, they'd also need to know *which* older plugin version is "good"
> > and should be downloaded.
> >> The former case, when the
> >> whole plugin is experimental, seems to be often misused: authors can use
> >> it to hide some specialised of localised plugisn from majority of users.
> >> In fact even I committed such clear misuse, marking the Plugin Reloader
> >> as experimental just to not clutter the list for normal users... Another
> >> reason could be a shyness. But again, we have the rating stars now and
> >> don't need to rely on the author's shyness anymore.
> >> So... Do you see important reasons to keep this tag? Maybe we should
> >> completely drop it? Or just remove the option to hide them from manager,
> >> leaving the flask icon on the plugin details page?
> > I think it should be kept. I know of one buggy plugin which recently
> > got marked as experimental, and I'm *very* glad to see this particular
> > plugin hidden from the majority of our users by default.
> > Nyall
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
