[QGIS-Developer] unable to build MacOS master (OpenCL)
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Mon Dec 3 00:01:52 PST 2018
I am unable to build QGIS master after Friday's changes in opencl header.
Any idea if I can still use official MACOS CL headers or how to proceed?
Thanks.
Peter
[ 19%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/geometry/qgsabstractgeometry.cpp.o
In file included from
/Users/peter/Projects/qgis1/QGIS/src/core/raster/qgshillshaderenderer.cpp:33:
/Users/peter/Projects/qgis1/QGIS/src/core/qgsopenclutils.h:25:
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1323:1:
error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_HOST_PROPERTIES'
CL_HPP_PARAM_NAME_INFO_2_0_(CL_HPP_DECLARE_PARAM_TRAITS_)
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1277:23:
note: expanded from macro 'CL_HPP_PARAM_NAME_INFO_2_0_'
F(cl_device_info, CL_DEVICE_QUEUE_ON_HOST_PROPERTIES,
cl_command_queue_properties) \
error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1278:23:
F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES,
'CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1279:23:
F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE, cl_uint) \
error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1280:23:
F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE, cl_uint) \
error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_QUEUES'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1281:23:
F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_QUEUES, cl_uint) \
error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_EVENTS'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1282:23:
F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_EVENTS, cl_uint) \
error: use of undeclared identifier 'CL_DEVICE_MAX_PIPE_ARGS'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1283:23:
F(cl_device_info, CL_DEVICE_MAX_PIPE_ARGS, cl_uint) \
error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1284:23:
F(cl_device_info, CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS, cl_uint) \
error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_PACKET_SIZE'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1285:23:
F(cl_device_info, CL_DEVICE_PIPE_MAX_PACKET_SIZE, cl_uint) \
error: use of undeclared identifier 'CL_DEVICE_SVM_CAPABILITIES'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1286:23:
F(cl_device_info, CL_DEVICE_SVM_CAPABILITIES,
cl_device_svm_capabilities) \
'CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1287:23:
F(cl_device_info, CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT,
cl_uint) \
'CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1288:23:
F(cl_device_info, CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT, cl_uint)
'CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1289:23:
F(cl_device_info, CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT, cl_uint) \
error: use of undeclared identifier 'CL_QUEUE_SIZE'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1290:30:
F(cl_command_queue_info, CL_QUEUE_SIZE, cl_uint) \
error: use of undeclared identifier 'CL_MEM_USES_SVM_POINTER'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1291:20:
F(cl_mem_info, CL_MEM_USES_SVM_POINTER, cl_bool) \
'CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1292:30:
F(cl_program_build_info, CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE,
size_type) \
error: use of undeclared identifier 'CL_PIPE_PACKET_SIZE'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1293:21:
F(cl_pipe_info, CL_PIPE_PACKET_SIZE, cl_uint) \
error: use of undeclared identifier 'CL_PIPE_MAX_PACKETS'
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1294:21:
F(cl_pipe_info, CL_PIPE_MAX_PACKETS, cl_uint)
/Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:3293:16:
error: unknown type name 'cl_svm_mem_flags'; did you mean 'cl_mem_flags'?
static cl_svm_mem_flags getSVMMemFlags()
/System/Library/Frameworks/OpenCL.framework/Headers/cl.h:67:29: note:
'cl_mem_flags' declared here
typedef cl_bitfield cl_mem_flags;
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
make[2]: ***
[src/core/CMakeFiles/qgis_core.dir/raster/qgshillshaderenderer.cpp.o] Error
1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make: *** [all] Error 2
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/e3f4637f/attachment-0001.html>
