[QGIS-Developer] Confused by Point vs. PointZ and LineString v. LineStringZ
C Hamilton
adenaculture at gmail.com
Tue Dec 4 07:40:24 PST 2018
I have been writing some code that maintains the Z dimension for vector
layers. When I create a layer from QGIS points whether it is a point or
line layer and I create the points with QgsPoint(x, y, altitude), I can do
this without using PointZ or LineStringZ layers and it maintains the Z axis.
What is the purpose of PointZ, LineStringZ, and PolygonZ? Is there a reason
I should be using them when Point, LineString, and Polygon seem to work the
same? Is there a reason I should not use the Z versions?
Thanks,
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181204/3e4904f5/attachment.html>
