[QGIS-Developer] MSSQL driver not found & Can't open lib 'SQL Server' - QGIS 2.18 LTR on Debian
kimaidou
kimaidou at gmail.com
Tue Dec 11 07:43:06 PST 2018
The primary keys were integer only. So the issues was not caused by
nvarchar as Pkeys. The issue was with nvarchars in general. This behaviour
can be tested with ogr2ogr by converting a table into a geojson or CSV ->
you will see hieroglyphs for exported nvarchar fields.
Le lun. 10 déc. 2018 à 01:03, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Sun, 9 Dec 2018 at 03:11, kimaidou <kimaidou at gmail.com> wrote:
> > Hi Nyall,
> > Thanks for your answer. I had already checked that the layers had
> integer primary keys. I have discovered that the "wrong" layers had
> "nvarchar" fields, instead of "varchar". We changed the types of the view
> fields from nvarchar to varchar, and it solved the issue.
> Can you elaborate here? Was the issue "nvarchars" in general? Or
> nvarchars used as primary keys?
> Nyall
> > Cheers,
> > Michaël
> > Le mer. 5 déc. 2018 à 23:55, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
> >> On Thu, 6 Dec 2018 at 05:37, kimaidou <kimaidou at gmail.com> wrote:
> >> > Thanks for your answers. I managed to connect with QGIS MSSQL native
> provider under my Debian box with the following steps
> >> > https://gist.github.com/mdouchin/64f7733a3c4ecfe441f65d5529351a30
> >> > I have a weird behaviour. For some layers, QGIS Desktop cannot
> display the features attributes : the attribute table is empty, and the
> identify tool returns no feature. BUT I can see the points in my map, so
> QGIS can query the geography field from the database. For some other
> layers, wich seems identical (same structure for example), I can see the
> attributes (full attribute table and identify OK)
> >> Sounds like an issue with fetching by primary key/feature ID. Is there
> >> any difference between the primary key setup on these tables vs the
> >> ones which work?
> >> Nyall
> >> > Have anyone seen this behaviour before ?
> >> > Cheers
> >> > Michaël
> >> > Le lun. 19 nov. 2018 à 00:12, Nyall Dawson <nyall.dawson at gmail.com>
> a écrit :
> >> >> On Sat, 17 Nov 2018 at 02:01, kimaidou <kimaidou at gmail.com> wrote:
> >> >> > Hi all,
> >> >> > I am trying to connect to a MSSQL server from a QGIS installed in
> a Linux Debian Jessie computer.
> >> >> > I have checked that the credentials are ok with the mssql-client
> from Microsoft:
> >> >> > mssql-cli -S myserver -U carto -P ******* -d MyBase
> >> >> > I installed the following packages from debian and Microsoft repos
> >> >> > curl https://packages.microsoft.com/keys/microsoft.asc | apt-key
> add -
> >> >> > curl https://packages.microsoft.com/config/debian/8/prod.list >
> /etc/apt/sources.list.d/mssql-release.list
> >> >> > apt-get update
> >> >> > ACCEPT_EULA=Y apt-get install -y mssql-cli unixodbc-dev
> mssql-tools msodbcsql17 msodbcsql odbcinst libqt4-sql-tds libqt4-sql-odbc
> >> >> > When I open QGIS and try to set up a connection, I use not DSN,
> and I put my server "myserver" as the host. I add the user and password.
> >> >> > Then try to list the databases, but I get this error
> >> >> > [unixODBC][Driver Manager]Can't open lib 'SQL Server' : file not
> found
> >> >> This is all super-fragile. (Just another symptom of SQL Server's
> >> >> inferiority IMO).
> >> >> Have a look at
> https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/docker-build-test.sh#L128
> >> >> for how the Travis testing environment sets up a connection, there
> may
> >> >> be some clues there.
> >> >> Nyall
> >> >> > I tested with
> >> >> > root at carto:~# odbcinst -j
> >> >> > unixODBC 2.3.1
> >> >> > DRIVERS............: /etc/odbcinst.ini
> >> >> > SYSTEM DATA SOURCES: /etc/odbc.ini
> >> >> > FILE DATA SOURCES..: /etc/ODBCDataSources
> >> >> > USER DATA SOURCES..: /root/.odbc.ini
> >> >> > SQLULEN Size.......: 8
> >> >> > SQLLEN Size........: 8
> >> >> > SQLSETPOSIROW Size.: 8
> >> >> > So I checked /etc/odbcinst.ini which seems ok
> >> >> > root at carto:~# cat /etc/odbcinst.ini
> >> >> > [ODBC Driver 17 for SQL Server]
> >> >> > Description=Microsoft ODBC Driver 17 for SQL Server
> >> >> > Driver=/opt/microsoft/msodbcsql17/lib64/libmsodbcsql-17.2.so.0.1
> >> >> > UsageCount=1
> >> >> > [ODBC Driver 13 for SQL Server]
> >> >> > Description=Microsoft ODBC Driver 13 for SQL Server
> >> >> > Driver=/opt/microsoft/msodbcsql/lib64/libmsodbcsql-13.1.so.9.2
> >> >> > UsageCount=1
> >> >> > Should I install more packages ? Any help appreciated.
> >> >> > Regards,
> >> >> > Michaël
> >> >> > _______________________________________________
> >> >> > QGIS-Developer mailing list
> >> >> > QGIS-Developer at lists.osgeo.org
> >> >> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> >> > Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181211/e4468bb1/attachment-0001.html>
