[QGIS-Developer] QGIS 3.4 - QWebView: Problem loading a website with javascript files
Matthias Kuhn matthias at opengis.ch
Thu Dec 13 07:02:10 PST 2018
We had a similar issue and I first thought it's the same. However, since
you say it's remote content out solution probably does not apply to you.
I'll post it here anyway for other people following.
We had to provide paths (to local files) on windows with forward slashes
to get it to work again.
Before file://C:\some\path\index.html
After: file:///C:/some/path/index.html
Regards
Matthias
On 12/13/18 12:34 PM, Tom Chadwin wrote:
> The only other thing I'd check (but this is not a change from 3.2 to 3.4) is
> that you are using QgsNetworkAccessManager, to tolerate any upstream proxy
> issues. Beyond that, you'd have to check the logs of the webserver which
> holds the JS, to see what's happening there.
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181213/e40c1043/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181213/e40c1043/attachment.png>
More information about the QGIS-Developer mailing list
