[QGIS-Developer] QgsSymbolButton/QgsFontButton no menu?
Nyall Dawson nyall.dawson at gmail.com
Sat Dec 15 13:41:58 PST 2018
On Sat, 15 Dec 2018 at 20:50, Jonas <qgis at ag99.de> wrote:
> Hi,
> i am currently working on fixing the inner paddings of the ToolButtons for
> Symbols (QgsSymbolButton) and Fonts (QgsFontButton) on non-windows platforms
> (the fontbutton for macOS has been fixed in
> https://github.com/qgis/QGIS/pull/8605
> <https://github.com/qgis/QGIS/pull/8605>  ).
> <http://osgeo-org.1560.x6.nabble.com/file/t384296/toolbuttons_2.png>
> can somebody explain to me the rationale to have differing icon widths if
> the button has no menu?
> see
> https://github.com/qgis/QGIS/blob/8a0a745677a8ff2c4631f451c9ed8fd7580ec220/src/gui/qgssymbolbutton.cpp#L468
> <https://github.com/qgis/QGIS/blob/8a0a745677a8ff2c4631f451c9ed8fd7580ec220/src/gui/qgssymbolbutton.cpp#L468>
I don't think these are required, and are just remnants of code copied
originally from the color button. As you've rightly concluded, it's
not possible to use the font/symbol button widgets without the menus.
Nyall
> i could imagine this would make sense if you could remove the arrow on the
> right to make the icon wider then, but i actually found no way to do this in
> c++ or python. but you can remove the menu without removing the arrow (eg
> setting QgsFontButton.setMenu(None) in PyQGIS) which triggers the
> alternative styling. it does not make sense but it makes the button look
> weird and also ... blurry on all platforms ?!??
> i would like to fix the padding and think that removing the check altogether
> is fine, but i am reluctant to move on as i am new around here.
> can somebody explain if there is a use case for the non-menu styling? Thanks
> Jonas (iona5)
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
