[QGIS-Developer] build error on: #elif QT_CONFIG(process) ?
Matthias Kuhn
matthias at opengis.ch
Thu Dec 20 03:32:16 PST 2018
Hi Richard,
Can you upload the complete build log to a gist or pastebin?
Thanks
Matthias
On 12/20/18 12:30 PM, Richard Duivenvoorde wrote:
> On 12/20/18 10:55 AM, Richard Duivenvoorde wrote:
>> Note that a fresh build here on my laptop (Debian Testing) just worked...
>> Nobody else sees this?
> Tried using make and ninja as build tools, no difference.
> Found this:
> https://stackoverflow.com/questions/21338385/what-does-the-compiler-error-missing-binary-operator-before-token-mean
> But we do not have a "features.h" in our code...
> This one
> https://forum.qt.io/topic/27925/solved-qt_deprecated_since-gives-error-missing-binary-operator-before-token-in-qnamespace-h/5
> is talking about a limits.h
> which we also do not have...
> Tried to remove the if else macro in qgsapplication.cpp
> But then I get other build errors in other files on lines containing:
> #if QT_CONFIG(process)
> After reading
> https://forum.kde.org/viewtopic.php?f=269&t=128141
> I thought that I could miss dependencies, so made sure to have installed
> all stuff for stretch from INSTALL.txt
> Still failing...
> Regards,
> Richard
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181220/40a7a4be/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181220/40a7a4be/attachment-0001.png>
