[QGIS-Developer] Keeping OTB algorithm in qgis processing
Werner Macho werner.macho at gmail.com
Thu Feb 1 02:07:16 PST 2018
Hi Alex,
Thats exactly what I meant.
I know that (currently) there are no plugin for SAGA and GRASS but if I
understood everything correctly the point is to create such plugins.
My Question was more or less if there is already code existing for it or if
we have to wait until they are removed before the plugins can appear - but
this is now answered.
Waiting for the plugins ;)
And hopefully good documentation howto bring new algorithms alive..
thanks and kind regards
Werner
On Thu, Feb 1, 2018 at 11:00 AM, Alexander Bruy <alexander.bruy at gmail.com>
wrote:
> Hi Werner,
> there are no plugins for SAGA and GRASS, but this is just because they
> are in core.
> Also seems we need to clarify, removal from core does not means wiping
> all stuff,
> this just mean that existing code will be separated into plugin and
> published on GitHub
> and QGIS plugins repository. Then interested people can take ownership
> and continue
> development and maintenance.
> Exactly in the same way we removed LiDAR tools provider (now
> maintained by Martin Isenburg)
> and TauDEM provider (maintained by me, along with several others
> Processing providers).
> 2018-02-01 10:39 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> > Hi all,
> > I am also in favour of removing all the work that is not directly
> related to
> > QGIS.
> > But I'd also like to ask if there is already a plugin available (on
> github?)
> > that for e.g. readds the GRASS functionality?
> > Furthermore I'd like to know if it is possible to create a plugin for
> > official stable GRASS and GRASS development version, which in the best
> case
> > can be installed side by side?
> > (Same applies to SAGA and all the other providers).
> > I am sure there is a huge possibility that an ecosystem will be created
> > around those kind of plugins.
> > kind regards
> > Werner
> > On Thu, Feb 1, 2018 at 9:33 AM, G. Allegri <giohappy at gmail.com> wrote:
> >> +1 also from me to the removal of the providers from core. IMHO I would
> >> also remove GRASS, but I understand it could be a tough decision.
> >> The provider system + plugin architecture provide all the means to keep
> >> them separate from the core.
> >> We all agree, I guess, that less is better then more, to guarantee the
> >> highest quality we can afford.
> >> Giovanni
> >> Il 1 feb 2018 09:23, "Paolo Cavallini" <cavallini at faunalia.it> ha
> scritto:
> >>> Hi Rashad,
> >>> Il 31/01/2018 10:43, Rashad Kanavath ha scritto:
> >>> > What I can propose is to lower the burden on maintenance but the code
> >>> > should be put back to qgis if possible.
> >>> > So qgis can focus on issue related only to that and after a while
> >>> > things
> >>> > will stabilize.
> >>> > Indeed, if there is something broken in this algo otb team will help
> >>> > fix it.
> >>> thanks for your offer, much appreciated. Would this include also the
> >>> inclusion of OTB in the standalone installers for Windows? It would be
> >>> good to make sure we always have the most appropriate version, both for
> >>> 32 and 64 bit.
> >>> All the best.
> >>> Paolo Cavallini - www.faunalia.eu
> >>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> >>> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180201/d6477920/attachment.html>
More information about the QGIS-Developer mailing list
