[QGIS-Developer] Kernel density of SAGA broken?
Giovanni Manghi giovanni.manghi at gmail.com
Thu Feb 1 03:04:55 PST 2018
Hi Matteo,
> Hi,
> sorry for continuing bombing the mailing list.
> I'm testing some random algorithms and it seems that the Kernel density
> of SAGA is broken. Or worst, it seems working, a kind of output is
> created (but it is not visible) and no error or stack traces.
did you try if the same operation (same inputs and parameters) also
fails using SAGA from the command line?
If yes then is a SAGA issue, if not is ours.
cheers!
-- G --
More information about the QGIS-Developer mailing list
