[QGIS-Developer] update of otb plugin for QGIS
Tisham Dhar
tisham.dhar at aerometrex.com.au
Thu Feb 1 18:56:29 PST 2018
Perhaps the plugin should provide an OTB binaries install mechanism once it runs and inspects the platform it is on.
From: Rashad Kanavath [mailto:mohammedrashadkm at gmail.com]
Sent: Wednesday, January 31, 2018 7:19 PM
To: Tisham Dhar <tisham.dhar at aerometrex.com.au>
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] update of otb plugin for QGIS
Hello,
On Wed, Jan 31, 2018 at 2:05 AM, Tisham Dhar <tisham.dhar at aerometrex.com.au<mailto:tisham.dhar at aerometrex.com.au>> wrote:
Hi Rashad,
I meant pre-built OTB binaries rather than plugin binaries. I believe QGIS builds on more platforms than OTB does.
plugin code is in python. so nothing much to worry on binaries part and they depend on qgis processing code.
QGIS had removed otb plugin from processing and kept others. So there is another stuff to work on user side and developer side.
Regards,
Tisham.
From: Rashad Kanavath [mailto:mohammedrashadkm at gmail.com<mailto:mohammedrashadkm at gmail.com>]
Sent: Tuesday, January 30, 2018 7:45 PM
To: Tisham Dhar <tisham.dhar at aerometrex.com.au<mailto:tisham.dhar at aerometrex.com.au>>
Cc: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Hell Tisham,
Can you explain the part of binaries issue?
The documentation of build from source is already there for OTB. The new module which if merged into Modules/Wrappers/QGIS will be like any other otb module.
Since there are no external dependencies, this could be enabled by default. So need to specific documentation to build it is not required.
But once the coding work is done, there will be another (RFC) and in that i will include the usage, builds options etc..
On Tue, Jan 30, 2018 at 1:10 AM, Tisham Dhar <tisham.dhar at aerometrex.com.au<mailto:tisham.dhar at aerometrex.com.au>> wrote:
Hi All,
I am an avid supporter to OTB and would love to see the plugin brought more in line with latest developments in OTB. The binaries issue will always exist and I believe OTB should support the same ones for which Qgis binaries are available already. The other platforms should have a clear build from source documentation. These should be listed in the RFC.
Regards,
Tisham Dhar
Research Engineer
Aerometrex PTY LTD
59 King William St.
Kent Town SA 5067<https://maps.google.com/?q=59+King+William+St.%0D+%0D+Kent+Town+SA+5067%0D+Australia&entry=gmail&source=g>
Australia<https://maps.google.com/?q=59+King+William+St.%0D+%0D+Kent+Town+SA+5067%0D+Australia&entry=gmail&source=g>
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Regards,
Rashad
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180202/6d7fa183/attachment-0001.html>
