[QGIS-Developer] Broken 'randomness' for new layer styles?
Richard Duivenvoorde rdmailings at duif.net
Fri Feb 2 03:52:20 PST 2018
Somebody (Raymond ;-) ) 'complained' to me that running a processing
algorithm everytime comes up with an (ugly) brown style.
While (I think) the styling of a newly added/created vector layer should
be more or less random..., what I see is that the colors (at least here
with me) often start with a couple of times brown, then another color
then again two times another color (exact same rgb values) etc etc.
So my question is:
- how 'random' should these colors be?
- would it be an idea to create some (nicer colored) color list, which
would then be used to select (random?) colors from.
To check:
- open (in master) whatever point layer.
- search for Buffer algo in processing toolbox
- double click it to show the dialog
- click 'Run in Background' button 10 times (with default values)
As an example the result with me here...
Regards,
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180202/087e43f2/attachment.png>
More information about the QGIS-Developer mailing list
