[QGIS-Developer] Issues with custom forms with Python (in both QGIS 2 and QGIS 3)
Tudor Barascu tudorbarascu at yahoo.com
Tue Feb 6 00:04:36 PST 2018
 Hi Victor,
I had the same problem in finding where to put the python logic in QGIS 3.Here you go: python_logic.jpg
Shared with Dropbox
In the image above it's a button on the right of the Provide ui-file and on the left of the "Show form on add feature...
Regards,TudorĀ
    On Tuesday, February 6, 2018, 9:33:27 AM GMT+2, Victor Olaya <volayaf at gmail.com> wrote:
 Hi
I am writing documentation about custom forms, but I am encountering some problems.
In the case of QGIS 2, it seems that there is no way of avoiding the dialog to be closed when the OK button is clicked. I read this blog post by Nathan, in which it disconnects the default 'accepted' signal from the 'dialog.accept' slot. I tried that, but it doesnt seem to be working. It runs the validation function that I connect to that signal, but even if I dont accept the dialog in that function, it closes it.
I also tried using the disconnectButtonBox() method of the QgsAttributeForm class, but it does nothing. The buttons still do their work.
Is this a bug, or I am doing something wrong?
In QGIS3, it seems that now only the ui file can be provided, but not a python file with the form logic. How is that added now?
Thanks!_______________________________________________
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180206/35a3ff96/attachment.html>
More information about the QGIS-Developer mailing list
