[QGIS-Developer] QGIS 3 layout: conversion from old template format ?
Hugo Mercier
hugo.mercier at oslandia.com
Tue Feb 6 05:18:01 PST 2018
Hi Alessandro,
That's great, thanks ! :)
On 06/02/2018 14:11, Alessandro Pasotti wrote:
> Hi Hugo,
> if the old composition was embedded in a project the conversion should
> happen automatically and you should see the old compositions in the
> layouts menu.
> There is a class to convert the 2.x composition to the new layouts:
> https://github.com/qgis/QGIS/blob/master/src/core/layout/qgscompositionconverter.h
> You can find some usage examples in
> https://github.com/qgis/QGIS/blob/master/tests/src/core/testqgscompositionconverter.cpp
> Cheers
> On Tue, Feb 6, 2018 at 2:01 PM, Hugo Mercier <hugo.mercier at oslandia.com
> <mailto:hugo.mercier at oslandia.com>> wrote:
> Hi,
> I have a project with lots of composer templates that have been designed
> before the new "layout" refactoring.
> Loading these old templates in a more recent version fails silently.
> Is there a way to convert from the old format to the new one ?
> Thanks.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
