[QGIS-Developer] [Server] Is QGIS Server 3 fast yet ? the 2018-02-06
Andreas Neumann a.neumann at carto.net
Thu Feb 8 06:59:14 PST 2018
Hi René Luc,
Good points. I also had a look at these stats and was disappointed.
So I agree that it would be worth-wile working on improving the
performance of QGIS server version 3.
On the QgsProject loading performance issue: is this only an issue at
the first loading of the project or every time a request is being made?
Definitely I would welcome a submission at the next round of QGIS grants
to further study the issues and improve perfomance were possible.
Thanks for your thoughts,
Andreas
On 2018-02-08 15:19, René-Luc Dhont wrote:
> Hi Devs,
> I have made some analyse of the performances data generated by CampToCamp test platform.
> The data are downloadable here https://gmf-test.sig.cloud.camptocamp.net/ms_perfs/
> And the tests are based on this docker-pull: https://github.com/camptocamp/ms_perfs
> The QGIS Server docker used for these tests are based on the Kartoza one updated by CampToCamp
> https://github.com/kartoza/docker-qgis-server It is based on Apache Server and FCGI.
> The data comes from OpenStreetMap and are stored in a PostgreSQL/PostGIS database.
> One type of request is tested, GetMap. Varoious number of simultaneous users and various scale
> are tested.
> To give an answer to the question : Is QGIS Server 3 fast yet ? , I only used the values for 10 simultaneous
> users.
> If the reference to the question is QGIS Server 2: QGIS Server 3 is NOT faster even with the trust option activated in the project.
> QGIS Server 3 is always slower than QGIS Server 2, when only one layer is requested.
> In the tests, QGIS Sever 3 is faster than QGIS Server 2 with multi-layers and complex styles.
> This result can be easily explain by the new way QGIS Server is loaded project. QGIS Server 3 uses the QgsProject class, so all the
> project : layers and layouts are loaded even if only one layer is requested.
> About the trust project option, the results are a little bit disappointing. The performances are not always better than without.
> For higher scale (1° by 800px), requests are slower, but for lower scale (0.015625° by 800px), they are faster.
> Now if we consired GeoServer-jai as a reference, QGIS Server 3 is slower in lower sacle (0.03125° by 800px)
> Now if we consired Mapserver as a reference, QGIS Server 3 is slower!
> We have to test some configuration:
> * disable simplify local
> * change simplify max scale
> Points of enhancement have to be explored :
> * Faster QgsProject loading based on project parsing
> * Simplify configuration at layer level
> * Completing trust option
> Regards,
> René-Luc
> * Enhance simplification
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180208/4e493107/attachment.html>
More information about the QGIS-Developer mailing list
