[QGIS-Developer] Processing Help system
Alexandre Neto
senhor.neto at gmail.com
Fri Feb 9 03:16:12 PST 2018
but yes, it's not an anchor that is created.
Alexandre Neto <senhor.neto at gmail.com> escreveu no dia sexta, 9/02/2018 às
11:12:
> I was able to use this local URL (note that I haven't renamed the rst file
> output/html/en/docs/user_manual/processing_algs/qgis/vector_analysis_tools.html#nearestneighbouranalysis
> Richard Duivenvoorde <rdmailings at duif.net> escreveu no dia sexta,
> 9/02/2018 às 11:10:
>> I thought wat Alexandre was saying was ok, but trying it out, it seems
>> just to create a 'span' with that id not a href#anchor ...
>> Anybody else can try?
>> Richard
>> On 09-02-18 11:55, Alexandre Neto wrote:
>> > From what I understand, we should stick to the algorithm ID. The
>> > provider is already implicit by the file structure. Assuming that that
>> > ID is unique across all the providers.
>> > processing_algs > qgis > vector analysis tools
>> > matteo <matteo.ghetta at gmail.com <mailto:matteo.ghetta at gmail.com>>
>> > escreveu no dia sexta, 9/02/2018 às 10:44:
>> > Hi Alexandre,
>> > > We don't need to change the algorithms titles, we just need to add
>> > an extra
>> > > anchor with the algorithm ID before it:
>> > > .. _nearestneighbouranalysis:
>> > > Nearest neighbour analysis
>> > > Description
>> > > <put algorithm description here>
>> > thanks for the hint.
>> > I've already put anchors before each algorithm, but with the
>> > provider name:
>> > .. _qgis_nearestneighbouranalysis:
>> > so I can get rid of the provider name and it should work correctly?
>> > Thanks
>> > Matteo
>> > Alexandre Neto
>> > @AlexNetoGeo
>> > http://sigsemgrilhetas.wordpress.com
>> > http://gisunchained.wordpress.com
> Alexandre Neto
> @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180209/1adb22a3/attachment.html>
