[QGIS-Developer] [Server] Is QGIS Server 3 fast yet ? the 2018-02-06
Yves Jacolin yjacolin at free.fr
Mon Feb 12 01:23:20 PST 2018
Hello,
One tells me that Camptocamp had wrote a proposition about performance
issue with PNG format. I will ask to Patrick if he can do more
performance profiling and if this proposition is still up to date.
Unfortunately not before next 2 weeks :(
Y.
Le 09/02/2018 à 14:54, Yves Jacolin a écrit :
> Hello all,
> Thanks René-Luc for this first analysis and all other for your though.
> Here some informations :)
> First I won't be at Madeira and this is the 2nd hackfest I missed in one
> year. That's a pity but I have a onsite trip for a customer each French
> holiday.
> But, I think Camptocamp has some R&D on QGIS performance so I will check
> this afternoon's meeting how we can start this. Performance improvement
> could be either analyze QGIS, add new test (GetFeatureInfo, etc.).
> René-Luc, could you open a ticket (if not already did) about any changes
> you think valuable?!
> Y.
> Le 08/02/2018 à 19:41, René-Luc Dhont a écrit :
>> Hi Régis
>> Le 08/02/2018 à 17:12, Régis Haubourg a écrit :
>>> Hi René Luc,
>>> thanks a lot for starting that analysis!
>>> Do you plan to be in Madeira? Elaborating a complete test suite
>>> together would be perfectly fitted for that task .
>> I could not be in Madeira. But we can discuss about perf test suite.
>>> Some questions:
>>> - Trust option is only there to not query datasource when this one
>>> has no metadata for PK and extent. So it should only make sense to
>>> compare the first getcapabilities or project load with and without
>>> trust option. Other following requests should not have any impact, so
>>> we need to make sure the platform is not measuring something else in
>>> the differences you note. So I don't see what you mean by
>>> "completing" the trust option. Can you be more explicit ?
>> Trust option can be usefull with Apache. When you use QGIS Server with
>> Apache, the QGIS Server processes are regularly reset. So the QGIS
>> Server cache is regularly cleaned, and the project is regularly
>> reloaded. So the trust option can affect all the request not only
>> GetCapabilities.
>> So the average time request is affected by trust option, but I was
>> thinking that this option make QGIS Server 3 faster at all scale and
>> it's not the case for high scale.
>> I have open an issue to request min,max, median requests time to have
>> an idea of the time needed to load project.
>>> - Is the test  platform requesting wms layer groups, and did you test
>>> the multithread rendering? How many cores? How many cores really
>>> available when testing?
>> The platform requesting layers, not layer groups and multithreading
>> rendering has been activated. the environnment variables are:
>>     QGIS_SERVER_PARALLEL_RENDERING: "true"
>>    QGIS_SERVER_MAX_THREADS: 8
>>> I think we should first elaborate a common reference test suite and
>>> couple a system monitoring at the same time to be sure we don't have
>>> external noise in the tests, and find system bottlenecks. Then only
>>> we can consider some conclusions over development priorities I think.
>> The platform provided by camptomcamp is a good start and some
>> enhancement has been already opened :
>> * test GetCapabilties
>> * test GetFeatureInfo
>> * test with labels
>> And we have multi options to test:
>> * with and without multithreading
>> * with and without local simplification (for postgres)
>> * with and without data projection (here form EPSG:4326 to EPSG:3857)
>> And we have other server configuration to test
>> * Nginx/Supervisor
>> * Embedding QGIS Server in Tornado or other Python server
>>> Many thanks !
>>> Régis
>> Regards,
>> René-Luc
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://yjacolin.gloobe.org
More information about the QGIS-Developer mailing list
