[QGIS-Developer] QGIS 3 itemById should return subclassed item
SIGéal
sigeal at sigeal.com
Mon Feb 12 11:51:39 PST 2018
This code used to work in QGIS 2.x.
|lblTitle =myComposition.getComposerItemById('title')|||lblTitle|.setText('New Title')|
|However, in QGIS |2.99, myLayout.itemById('title') returns this error :
|'QgsLayoutItem' object has no attribute 'setText'|
This problem is related to the following issue :
https://issues.qgis.org/issues/17152
The following workaround still works :
https://github.com/inasafe/inasafe/blob/develop/safe/report/processors/default.py#L54
Can this be corrected in QGIS 3.0 ?
Christophe
Le 28/11/2017 à 14:45, SIGéal a écrit :
> print(lblTitle) gives "<qgis._core.QgsComposerItem object at
> 0x0000029B1435FC18>"
> as suggested the error message.
> Christophe
> Le 28/11/2017 à 14:25, SIGéal a écrit :
>> Weird : lblTitle.type() returns "65639"...
>> Christophe
>> Le 28/11/2017 à 11:47, Matthias Kuhn a écrit :
>>> I guess there's a problem with the %ConvertToSubClassCode in the sip
>>> file.
>>> What does lblTitle.type() give?
>>> Matthias
>>> On 11/28/2017 11:22 AM, Etienne Trimaille wrote:
>>>> We have this problem with QGIS 2.18 too in our plugin:
>>>> https://github.com/inasafe/inasafe/issues/4271
>>>> We could fix the problem with a hint from Martin, we have this
>>>> function as a workaround:
>>>> It works well. It would be nice to know if it's a bug in QGIS.
>>>> Etienne
>>>> 2017-11-28 11:06 GMT+01:00 SIGéal <sigeal at sigeal.com
>>>> <mailto:sigeal at sigeal.com>>:
>>>> Hi devs,
>>>> |However, it doesn't anymore in QGIS |2.99.
>>>> Instead it returns this error :
>>>> |'QgsComposerItem' object has no attribute 'setText'|||
>>>> Christophe
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> <mailto:QGIS-Developer at lists.osgeo.org>
>>>> List info:
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>> Unsubscribe:
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180212/9084ceff/attachment-0001.html>
