[QGIS-Developer] QGIS3: Python QgsFeatureRenderer subclass problem
Nyall Dawson
nyall.dawson at gmail.com
Mon Feb 12 21:51:33 PST 2018
On 11 February 2018 at 21:07, Chris Crook <ccrook at linz.govt.nz> wrote:
> Hi Nyall
> The code is on github ..
> https://github.com/ccrook/QGIS-VectorFieldRenderer-Plugin/tree/qgis3_wip
> I've documented this in issue 8 at:
> https://github.com/ccrook/QGIS-VectorFieldRenderer-Plugin/issues/8
> Any thoughts would be greatly appreciated :-)
Ok, so the issue is that you're trying to call the base class methods by calling
QgsFeatureRenderer.startRender(context,fields)
That's not valid syntax. In Python 3 you should use:
super().startRender(context,fields)
Fixing those calls avoids the assert.
...BUT....
You'll get a lot of crashes, because there's other parts of your
renderer which need upgrading to QGIS 3.0 API. And unfortunately when
a renderer crashes in Python code, it segfaults after dumping the
python error to the console. You'll need to run in a console to see
the Python errors which are thrown and upgrade the corresponding API
calls.
Also - I noticed you access a layer from the project within your
startRender method -- is is very unsafe for a renderer to do, since it
is running in a background thread and should not be accessing layers
at all. Just another thing to try to refactor out as you upgrade your
plugin for 3.0!
Nyall
