[QGIS-Developer] Read QgsProject properties
Gerald Kogler geraldo at servus.at
Wed Feb 14 13:49:55 PST 2018
2.18
thanks
Gerald
On 14/02/18 02:06, Gerald Kogler wrote:
> 2.x
> On 14/02/18 00:47, Nyall Dawson wrote:
>> On 14 February 2018 at 08:51, Gerald Kogler <geraldo at servus.at> wrote:
>>> Hi,
>>> I'm doing my first explorations into pyqgis and I'm quite amazed,
>>> compliments for the design of the QGIS API!
>>> So far I recursively read layer groups and layers from QgsProject and
>>> write a json file which I then use to build a layer switcher for Openlayers.
>>> Now I need to add additional information which is part of .qgs project
>>> file, but I don't have any clue how to access it without parsing the
>>> XML. Everything from .qgs can be read by API methods?
>>> For example, I want to add to each layer its "Identifiable" info. There
>>> is a XML tag called <Identify> in .qgs, how do I get there? I tried with
>>> readEntry() and readListEntry() but without success.
>>> Or is there any handy reference of all the project properties and how to
>>> read them by the API?
>> The answer depends which QGIS version you're targetting. Are you
>> developing for 2.x or 3.0?
>> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
