[QGIS-Developer] QGIS3 - processing python script. Read features from output layer
Salvatore Larosa
lrssvtml at gmail.com
Thu Feb 15 13:39:56 PST 2018
Hi Michaƫl,
On Thu, Feb 15, 2018 at 6:36 PM, kimaidou <kimaidou at gmail.com> wrote:
> Hi all,
> I have a simple processing python alg which
> * generates a buffer with qgis:buffer
> * use qgis:fieldcalculator to add an buf_area field -> the output vector
> of my alg is this buffer+new field.
> I would like to parse the features of the output vector in order to gather
> some information and put it in a new string output. I have not been able to
> get the layer object to perform a getFeatures on it.
> See the code
> http://paste.debian.net/1010463/
> In line 32, my blayer is None
> I think I am not using the good way to get the output vector layer
> features? I tried to use the same way as for reading an input layer, but
> oviously it is different.
What does happen if you put area_result['OUTPUT'] directly instead of
self.parameterAsSource?
parameterAsSource() accept a parameter as first argument and area_result
should be already un QgsVectorLayer.
Where you are trying to execute it from?
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180215/9a3a9b95/attachment.html>
