[QGIS-Developer] Upcoming PROJ 5.0.0 release
Kristian Evers kreve at sdfe.dk
Mon Feb 19 06:39:45 PST 2018
Dear QGIS developers,
As some of you may know, a new version of the PROJ library is about to be released. At the moment we are on release candidate 3 [0].
It is very likely that this release candidate will be promoted to the final release. Before that happens though, I want to make sure
that we are not breaking the interface to QGIS. I don't expect this to happen but since the internals of the library has undergone
major surgery some testing of this is warranted. Especially in QGIS which is too important to not work with a new major release of
PROJ.
So, has anyone from the dev team successfully build QGIS against the current release candidate? And if not, would someone be
willing to spend a bit of time testing if everything works as expected? I know this is a bad time since everybody is busy with
QGIS3, but nonetheless a quick check confirming that the new major versions of both QGIS an PROJ works together will be good
for both projects.
Thanks in advance,
Kristian
[0] http://lists.maptools.org/pipermail/proj/2018-February/007990.html
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180219/f63ffbc0/attachment.html>
More information about the QGIS-Developer mailing list
