[QGIS-Developer] Data defined @symbol_color outlines
McDonaldR McDonaldR at angus.gov.uk
Fri Feb 23 01:01:18 PST 2018
Thanks for letting me know, Nyall
All the best with the 3.0 release today!
Ross
-----Original Message-----
From: Nyall Dawson [mailto:nyall.dawson at gmail.com]
Sent: 22 February 2018 23:09
To: McDonaldR
Cc: qgis-user at lists.osgeo.org; qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] Data defined @symbol_color outlines
On 22 February 2018 at 01:31, McDonaldR <McDonaldR at angus.gov.uk> wrote:
> Hi List
> This issue (https://issues.qgis.org/issues/15132) refers to using the
> @symbol_color function to make the outline of graduated/categorised
> features the same colour as the fill.  There is a fix by Nyall from
> over a year ago but I wonder if there has been a regression?
> I am using both the latest 2.99 master and 2.18.16 64-bit versions on
> Windows 7 and if I render a polygon layer using the categorised or
> graduated renderer and set the outline colour using @symbol_color then
> the legend doesn’t reflect the style shown on the map. The features
> are rendered correctly (I like using “darker(@symbol_color,150)”) on
> the map canvas and the print composer but the legend in the table of
> contents and on the composer layout show the default outline colour.
This has never been supported - all data defined properties don't currently play well with the layer tree or map legends (and never have). Maybe something for 3.2...
Nyall
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
More information about the QGIS-Developer mailing list
