[QGIS-Developer] Where are value maps / defaults stored on shape file layers?
Matthias Kuhn matthias at opengis.ch
Sat Feb 24 03:46:25 PST 2018
Hi Patrick,
You are correct, this data is stored in the project file. If the project
hasn't been saved prior to the crash, this configuration is lost.
There is definitely a good reason to report an issue, because the app
crashed. Please provide as much information as possible that can help as
a lead why this happened (a backtrace of the crash being the most useful
one; and an exact description of at what point and after what actions it
happened being inevitable).
To avoid loss of work, there is an autosaver plugin
(https://plugins.qgis.org/plugins/autoSaver/) that regularly saves the
project configuration. I'm not sure it's updated to QGIS 3 yet.
Regards
Matthias
On 02/24/2018 08:05 AM, Patrick Dunford wrote:
> It would seem this data is stored in the project file?
> Given I can't produce a corrupted project file (I can only produce the
> files for the affected laye) is there any point in filing a bug for this.
> On 24/02/18 20:01, Patrick Dunford wrote:
>> Good evening (here)
>> I had Qgis 2.99 crash and it left the shape file data with three of
>> the data files that make up the shapefile, with _packed in their name.
>> Although renaming the files got the data back, the value maps and
>> default values for new features for this layer have disappeared.
>> Is there a particular file that stores this data for the layer
>> (before I decide whether this could be a bug or not)?
>> Thanks
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
