[QGIS-Developer] Vector tiles
Even Rouault even.rouault at spatialys.com
Tue Feb 27 12:54:32 PST 2018
Tom,
This has been somehow discussed in https://trac.osgeo.org/gdal/ticket/7228
Bottom line is that the multi-scale approach of vector tiles doesn't fit well with the
traditional scale-agnostic vector layer approach. So somehow you need to assign each
vector tile zoom level to a cartographic scale range.
Another thing not covered by the OGR MVT driver is the merging of the geometries of
identical linear and area features split over several tiles (when iterating over a high zoom
level with many tiles, doing that would have serious memory & processing time
implications. When doing that for typical display purposes when you have just a few tiles
opened at a time, this is something that can be done more reasonably).
The OGR MVT driver will appear in GDAL 2.3.0, expected to be release around May.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180227/357f2e3a/attachment.html>
More information about the QGIS-Developer mailing list
