[QGIS-Developer] QGIS 3D: Support for 3DM (x,y,z,m)
Jakob Lanstorp
jlanstorp at gmail.com
Fri Jan 5 05:31:56 PST 2018
Is it correct that the 3D engine currently does not understand measurement
values in 3DM format.
When having four numbers in a coordinate the z (and m) value is skipped
rendering the geometry af terrain = 0 meter (any 2d layer in 3D map is
default rendered at z=0).
Example:
/SELECT
1 AS id,
ST_GeomFromText('MULTIPOINT(505105 6305783 100 111, 504809 6305233 200
222)', 25832) AS geom/
Jakob Lanstorp
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
