[QGIS-Developer] Learning the node tool in 2.99
    Alexandre Neto
    senhor.neto at gmail.com
    Sat Jan  6 04:31:38 PST 2018
Hi Harrissou,
Check this blog post, day 13. You add a new vertex by click and drag the
cross between two vertexes.
Not sure about the node selection.
Alex Neto
A sex, 5/01/2018, 16:13, DelazJ <delazj at gmail.com> escreveu:
> Hi,
> I'm sure we had this discussion in the past but couldn't find a discussion
> with outcomes. I'm doing some digitizing these days, using master and still
> fail to know how i should proceed for some actions:
> - how do I add a simple vertex on a line? with the click-click system, it
> wants me to move the vertex. However, while writing the message, found out
> that doing three simultaneous clicks does the job (as well as a
> double-click combined to snapping on the line). Am I correct or is there an
> easier process?
> - How do I add nodes to selected ones? ie, I made a click and drag with
> the node tool and got too much nodes (sometimes from other features) or not
> enough nodes. How do I update the selection?
> Btw opening the vertex editor panel for a feature does not show selected
> vertices (see https://issues.qgis.org/issues/17806)
> I have other questions but let's fix these ones and I think answers may
> help me deal with the rest.
> Thanks,
> Harrissou
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180106/47993aa9/attachment.html>
