[QGIS-Developer] GRIB files projection errors
Paolo Cavallini cavallini at faunalia.it
Tue Jan 9 12:14:36 PST 2018
Hi Saber,
thanks for checking. The sample mentioned in the ticket loads fine, but
its SRS is not recognized correctly (it appears as a custom EPSG,
whereas it should be 4326, I guess).
Further tests reveal that other gribs (downloaded with ZyGrib) have an
incorrect extent, and there fore are not loaded correctly. You can check
yourself or use this sample:
http://www.faunalia.eu/~paolo/grib2.bz2
As for crayfish, I'd need a solution using plain QGIS, as I'd like to
build a plugin based on grib. Furthermore, I would not like to use
non-Debian binaries on my system.
All the best.
Il 09/01/2018 14:53, Saber Razmjooei ha scritto:
> Hi Paolo,
> It works fine for me.
> Have you tried to open it with Crayfish as it will handle the bands
> properly?
> Regards
> Saber
> On 9 January 2018 at 12:08, Paolo Cavallini <cavallini at faunalia.it
> <mailto:cavallini at faunalia.it>> wrote:
>     Hi all,
>     loading a GRIB file does not work properly, because of a projection and
>     extent issue (mentioned in https://issues.qgis.org/issues/17219
>     <https://issues.qgis.org/issues/17219>).
>     The issue may reside in GDAL. Has anyone already worked on this?
>     Thanks.
>     Paolo Cavallini - www.faunalia.eu <http://www.faunalia.eu>
>     QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>     <http://www.faunalia.eu/training.html>
>     https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
>     <https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis>
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Saber Razmjooei
> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
> +44 (0)7568 129733
More information about the QGIS-Developer mailing list
