[QGIS-Developer] Migrating plugins
Javier Becerra Elcinto javier at panoimagen.com
Thu Jan 11 04:51:25 PST 2018
Hi Richard,
My bad, I did not notice that I was logged in in a different browser, I
just assumed I did not have the proper rights to edit it. When logged in
I see the edit button properly ;)
I will add it to the wiki myself.
Thanks, and sorry for the noise...
Javier
El 11/01/2018 a las 13:36, Richard Duivenvoorde escribió:
> Hi Javier,
> The wiki is 'just' a github wiki. Can you try to edit it with your
> github credentials? Or create a github account for it?
> If that fails, I'll try to copy your info in it.
> Regards,
> On 11-01-18 09:44, Javier Becerra Elcinto wrote:
>> Hi Paolo,
>> Thanks for the effort of setting up the wiki page, we have started
>> migrating some plugins and missed some kind of "standard"
>> guidelines/best practices.
>>   I was not able to find a way to contribute to the wiki, and could not
>> find an issue/forum associated with it - I do not know much about QGis'
>> team development workflow, so that there may be resources I am not aware
>> of (in that case, it might be a good idea to link them from the wiki?).
>> So I guess this list is the way to go at the moment, I will share my two
>> cents based on our experience migrating to QGis3 (we have recently made
>> a pull request to complete the migration of profiletool plugin to QGis3
>> https://github.com/PANOimagen/profiletool/commit/2631bc4600938d7beeaf6281bcb8de16a6de912c
>> and are working on other internal plugins):
>> -We iniatially thought on creating a compatibility layer to allow Qgis2
>> plugins to run (mostly?) unmodified on QGis3; however that seems like a
>> bad idea in the long term, and followed the monkey-patching strategy set
>> forth by opengis.ch in their qgis2compat plugin
>> (https://github.com/opengisch/qgis2compat). This means, we make all the
>> code qgis3 compatible, and patch QGis2 on runtime to provide Qgis3 api
>> compatibility. In the long term, dropping support for QGis2 should be as
>> simple as removing the apicompat module, the plugin's code would remain
>> unmodified to keep on running on QGis3.
>> -Unfortunately qgis2compat has not been updated in the last 10 months,
>> and we do not want to add an additional dependency to the plugins, so
>> that we have included their apicompat files as needed and completed the
>> missing bits we found (e.g. QgsPointXY). We can contribute our additions
>> to Qgis2compat if someone is interested.
>> -There are however some modifications that we have not been able to
>> manage with monkeypatching, for instance
>> PyQt4.QFileDialog.getOpenFilenames returns a list of files and
>> PyQt5.QFileDialog.getOpenFilenames returns a tuple with the list of
>> files and the extensions (i.e. PyQt5.QFileDialog.getOpenFilenames ==
>> PyQt4.QFileDialog.getOpenFilenamesAndFilter); modifying PyQt4's
>> behaviour can lead to other plugins, who expect the proper PyQt4 api, to
>> stop working. We prefer not to introduce 'new' functions (i.e.
>> PyQtx.QFileDialog.getOpenFilenames5) that would not be neither PyQt4 nor
>> PyQt5, and the best option we have found is to check PyQt version or use
>> a try/except to manage compatibility. We do not like it, but it is the
>> least ugly solution we could find. If someone has a nicer/more
>> elegant/more pythonic solution we are willing to hear from you :)
>> Regards,
>> Javier
>> El 09/01/2018 a las 11:17, Paolo Cavallini escribió:
>>> Il 09/01/2018 11:13, Werner Macho ha scritto:
>>>> Hi Paolo,
>>>> Good initiative!
>>>> I will contribute if I find anything important to say. ;)
>>> Thank you Werner. Any help will be useful, both in writing the guide and
>>> in testing and streamlining it.
>>> All the best.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
