[QGIS-Developer] Python question: QgsVectorLayer object has no attribute 'pendingFields'
Andreas Neumann a.neumann at carto.net
Mon Jan 15 09:10:39 PST 2018
I am trying to fix some Python code that worked before, but not anymore
due to API changes in master meanwhile.
I am getting a reference to a layer by name and then want to query the
'pendingFields'. Here is the code I use:
LayerParcels=
QgsProject.instance().layerStore().mapLayersByName('Parcels')[0]
newParcel = QgsFeature()
newParcel .setFields(LayerParcels.pendingFields())
The first two lines seem to work, but the third line triggers an error:
AttributeError: 'QgsVectorLayer' object has no attribute 'pendingFields'
Why is that?
This code worked a few weeks before and the 'pendingFields' - according
to https://qgis.org/api/classQgsVectorLayer.html still exists?
What is wrong with my code?
Thanks for any hints!
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/982580da/attachment.html>
More information about the QGIS-Developer mailing list
