[QGIS-Developer] Python question: QgsVectorLayer object has no attribute 'pendingFields'
Etienne Trimaille
etienne.trimaille at gmail.com
Mon Jan 15 09:14:37 PST 2018
pendingFields is gone this morning: https://github.com/qgis/QGIS/pull/6050
Maybe just use `fields()` ?
2018-01-15 20:10 GMT+03:00 Andreas Neumann <a.neumann at carto.net>:
> Hi,
> I am trying to fix some Python code that worked before, but not anymore
> due to API changes in master meanwhile.
> I am getting a reference to a layer by name and then want to query the
> 'pendingFields'. Here is the code I use:
> LayerParcels= QgsProject.instance().layerStore().mapLayersByName('
> Parcels')[0]
> newParcel = QgsFeature()
> newParcel .setFields(LayerParcels.pendingFields())
> The first two lines seem to work, but the third line triggers an error:
> AttributeError: 'QgsVectorLayer' object has no attribute 'pendingFields'
> Why is that?
> This code worked a few weeks before and the 'pendingFields' - according to
> https://qgis.org/api/classQgsVectorLayer.html still exists?
> What is wrong with my code?
> Thanks for any hints!
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/40d21383/attachment.html>
