[QGIS-Developer] Python question: QgsVectorLayer object has no attribute 'pendingFields'
Denis Rouzaud denis.rouzaud at gmail.com
Mon Jan 15 09:32:00 PST 2018
For reference, https://github.com/qgis/QGIS/pull/6050
As pointed out, Feature freeze != API freeze.
Many issues are still open here
https://github.com/qgis/qgis3.0_api/issues
Best,
Denis
Le lun. 15 janv. 2018 à 13:18, Andreas Neumann <a.neumann at carto.net> a
écrit :
> Hi,
> oh - thanks, Etienne and Alessandro. If this change is that recent, than
> it explains why the API doc and the API break document doesn't mention it:
> https://qgis.org/api/api_break.html
> But - aren't we in hard freeze (no more API changes) now since a few days
> already?
> Being confused ....
> Andreas
> On 2018-01-15 18:14, Etienne Trimaille wrote:
> pendingFields is gone this morning: https://github.com/qgis/QGIS/pull/6050
> Maybe just use `fields()` ?
> 2018-01-15 20:10 GMT+03:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I am trying to fix some Python code that worked before, but not anymore
>> due to API changes in master meanwhile.
>> I am getting a reference to a layer by name and then want to query the
>> 'pendingFields'. Here is the code I use:
>> LayerParcels=
>> QgsProject.instance().layerStore().mapLayersByName('Parcels')[0]
>> newParcel = QgsFeature()
>> newParcel .setFields(LayerParcels.pendingFields())
>> The first two lines seem to work, but the third line triggers an error:
>> AttributeError: 'QgsVectorLayer' object has no attribute 'pendingFields'
>> Why is that?
>> This code worked a few weeks before and the 'pendingFields' - according
>> to https://qgis.org/api/classQgsVectorLayer.html still exists?
>> What is wrong with my code?
>> Thanks for any hints!
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/b22d3161/attachment.html>
More information about the QGIS-Developer mailing list
