[QGIS-Developer] Translation state of master
Borys Jurgiel
lists at borysjurgiel.pl
Mon Jan 15 10:22:19 PST 2018
Thanks Andreas for raising this problem.
Werner, I'd say it more clearly: since we started using Transifex, the
translations are stuck there, and only rarely they land in qit. Last time it
was in June 2016 in QGIS 2.16, so QGIS 2.18 and 3.0 still contain the 2.16
translations.
I still don't understand why we keep the translations away from QGIS, but what
about pulling them to master asap, so early testers have a chance to find
mistakes?
I believe it's not only Polish problem that Transifex introduced tons of
embarrassing mistakes and disinformations. People are now translating without
seeing the context, so the quality of translation in Transifex is ridiculous
(subjects swapped with predicates and attributes - say 'layer style' with
'style layer', a raster confused with a net etc). I guess we should give it as
long testing period before the release as possible...
Regards,
Borys
On poniedziałek, 15 stycznia 2018 18:40:20 CET Werner Macho wrote:
> Hi Andreas,
> Could you give an example of what it not translated to german?
> Because according to transifex master is translated 100%.
> Is it a self compiled QGIS and you did not pull the translations from
> transifex in?
> Is it an old master compilation with old translations?
> Probably it is even a test-master without the newest translations pulled in.
> I think Jürgen can tell when exactly the translations get pulled in for the
> release.
> regards
> Werner
> On Mon, Jan 15, 2018 at 2:48 PM, Andreas Neumann <a.neumann at carto.net>
> wrote:
> > Hi,
> > Every once in a while I change from the english language (my personal
> > favourite) to german language, because some of my users prefer the german
> > interface and I need to explain the german terms. Switching the master
> > version to german I was a bit surprised to see a lot of english terms in
> > the german UI. Is translation something that will happen now, meaning in
> > the time between feature freeze and release?
> > Should I assist in the german translation process or is someone already
> > working on it?
> > Yet another reason not to release too soon, I think ...
> > Thanks and greetings,
> > Andreas
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
