[QGIS-Developer] Downloading qgis_de.ts file
Andreas Neumann a.neumann at carto.net
Tue Jan 16 12:22:40 PST 2018
Hi Richard,
Thanks for approving the request. I can now download the ts files fine.
Learning bit by bit about the QGIS infrastructure ;-)
I had no idea that Transifex is so restrictive with read-only access to
ts_file - What is the reason for the secrecy? Why can't the ts_file be
available for download without a registration and joining of a team? I
assume this is a decision from Transifex and not from QGIS - right?
Thanks a lot to all who helped!
Andreas
On 16.01.2018 08:36, Richard Duivenvoorde wrote:
> On 16-01-18 07:25, Andreas Neumann wrote:
>> Hi devs,
>> Can someone provide me please access to a current qgis_de.ts file?
>> I tried to join QGIS Transifex, but miserably failed. First, it did not
>> let me login with my github login (don't know why they offer this option
>> then), then after creating a user it did not let me join the QGIS
>> organization and apparently it does require me to have a login just for
>> downloading a ts file - not so nice!
>> Also, it doesn't fit the "open" mentality of QGIS, if one has to first
>> create a login just to download a file!รจ
>> I would really appreciate if someone could just send me a current
>> version of the file or a download link to it.
> Hi Andreas,
> you were not yet a 'member' of the translation team.
> I just approved your request, so now you can see/translate/download if
> you want.
> Note that if you download / translate / upload again, that you overwrite
> translations done in that time frame, unless there is some blocking
> possibility. Which I can not find on this moment...
> Regards,
> ps another possible online service coming from the Debian tribe is
> 'Weblate', which you can use hosted or run your self: true FOSS:
> https://weblate.org
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
