[QGIS-Developer] Processing plugin - Set style on resulting layer
Jakob Lanstorp
jlanstorp at gmail.com
Thu Jan 18 04:33:45 PST 2018
My bad ...
Actually I was not using the output.getVectorWriter object the correct way.
After fixing it the layer extracting from postgis by uri resulted in the
default layer style from postgis to be add automatically using the
getVectorWriter of the processing.core.outputs.OutputVector object.
If would still be smart if one could have an after processAlgorithm signal
for setting other stuff like adding feature count in TOC.
Jakob
Jakob Lanstorp
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
