[QGIS-Developer] Factorizing a dbf
Paolo Cavallini
cavallini at faunalia.it
Tue Jan 23 22:46:15 PST 2018
Il 24/01/2018 07:37, Nyall Dawson ha scritto:
> How would you see this working within processing? I guess you could
> select all the desired columns, and then an auto-generated field name
> could be made for each new field based on the original column. It's
> probably best left to a separate algorithm though.
yes, perfect
>> one further improvement would be to automatically add in the layer
>> property style the summary table as Value map.
> Good idea. This relates to a request on this list a week or so ago,
> where someone wanted an algorithm to be able to specifically set the
> style of generated layers. There's currently no support for this in
> processing algorithms, but there's no reason (well... apart from
> time/cost) we can't add it in for >= 3.2.
this is the way GRASS has worked from years; very practical, I miss that
in QGIS.
>> should I open feature reqs for this?
> Yes
will do it for both ASAP
thanks a lot for your thoughts
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
