[QGIS-Developer] QGIS3: reminder of an annoying bug
Daan Goedkoop
dgoedkoop at gmx.net
Wed Jan 24 06:20:10 PST 2018
Here is a sample project file.
2018-01-24 14:10 GMT+01:00 Jürgen E. Fischer <jef at norbit.de>:
> Hi Daan,
> On Wed, 24. Jan 2018 at 13:20:56 +0100, Daan Goedkoop wrote:
>> E.g. a project with the CRS set to 25833 (ETRS89/UTM zone 33N) in 2.18
>> will open with CRS 3006 (SWEREF99 TM) in the current QGIS 3.0.
>> 2018-01-20 18:05 GMT+01:00 Jürgen E. Fischer <jef at norbit.de>:
>> > I guess you see the problem with prj from third parties that use different
>> > projection names. And hence there may be no clue left in the prj that could
>> > help with identifying whether it's EPSG:3044 or EPSG:25832. How do your .prj
>> > actually look like?
> That a project is also affected is unexpected. Sample data?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180124/4aee6893/attachment-0001.obj>
