[QGIS-Developer] QgsExpression python pattern
Chris Crook
ccrook at linz.govt.nz
Wed Jan 31 11:45:43 PST 2018
I am updating some plugins which use QgsExpression, and I'm wondering about the best way to use expressions in QGIS3. It in the past I used a pattern like:
exp=QgsExpression(expressionText)
exp.prepare(fields)
request=QgsFeatureRequest()
request.setSubsetOfAttributes( expression.referencedColumns(), fields )
for feat in layer.getFeatures(request)
value=expression.evaluate(feat)
However with QGIS3 this has clearly changed! QgsExpression is not included in the QGIS3 API https://qgis.org/api/annotated.html. The prepare and referencedColumns are no longer defined. I did have a look at the C++ code for QgsExpression, but I find I'm still looking for guidance.
I've searched the QEP issues been able to locate a QEP, or other documentation. Can anyone point me to some documentation or provide an example of current best practice please.
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
