[QGIS-Developer] QgsExpression python pattern
Nyall Dawson
nyall.dawson at gmail.com
Wed Jan 31 13:25:34 PST 2018
On 1 February 2018 at 05:45, Chris Crook <ccrook at linz.govt.nz> wrote:
> I am updating some plugins which use QgsExpression, and I'm wondering about the best way to use expressions in QGIS3. It in the past I used a pattern like:
> exp=QgsExpression(expressionText)
> exp.prepare(fields)
> request=QgsFeatureRequest()
> request.setSubsetOfAttributes( expression.referencedColumns(), fields )
> for feat in layer.getFeatures(request)
> value=expression.evaluate(feat)
> However with QGIS3 this has clearly changed! QgsExpression is not included in the QGIS3 API https://qgis.org/api/annotated.html.
That's a bug with the generated docs (fix incoming ) - it's still
around. BTW you may prefer the work-in-progress Python API docs here:
http://python.qgis.org/api/
> The prepare and referencedColumns are no longer defined. I did have a look at the C++ code for QgsExpression, but I find I'm still looking for guidance.
> I've searched the QEP issues been able to locate a QEP, or other documentation. Can anyone point me to some documentation or provide an example of current best practice please.
Best place to check first is the API breaks docs:
https://qgis.org/api/api_break.html
This details the changes in QgsExpression (amongst all the other classes).
Hope that helps!
Nyall
