[QGIS-Developer] QGIS black startup?
Richard Duivenvoorde rdmailings at duif.net
Tue Jul 3 03:34:47 PDT 2018
Last days, I experience some strange startup behaviour:
- after starting up, the window of QGIS starts black and stays (at this
moment for 13 seconds) that way. And then starts up fine.
I've also experienced longer times.
I'm not connected at this moment (is QGIS/plugins/locators trying to do
network requests?)...
Ok, it seems network related, turning on wifi (or proxy), QGIS is fine...
Disabling all plugins, still black.
Removing plugins, still black.
Removing all connections and 'recent projects' from Browser/Connection
manager: OK..
It's not fully clear to me what is the problem, but I'm curious if
others experience such behaviour (with current master only)?
Even without network, QGIS should startup fine isn't it, even when
something is requesting network resources?
Sorry for not being more reproducible.
Regards,
PS: Setting QGIS_DEBUG=8 I get following debug info, but I cannot see
any blocking signs:
$ qgis3
src/app/main.cpp: 454: (main) [0ms] Starting qgis main
src/core/qgsapplication.cpp: 633: (resolvePkgPath) [82ms]
/home/richard/bin/qgis/master/debug/bin/qgisbuildpath.txt
src/core/qgsapplication.cpp: 633: (resolvePkgPath) [0ms]
/home/richard/bin/qgis/master/debug/bin/../qgisbuildpath.txt
/home/richard/bin/qgis/master/debug/bin/bin/qgisbuildpath.txt
/home/richard/bin/qgis/master/debug/bin/../../../qgisbuildpath.txt
src/app/main.cpp: 864: (main) [1ms] User profile details:
src/app/main.cpp: 865: (main) [0ms] 	 - rivm
src/app/main.cpp: 866: (main) [0ms] 	 -
/home/richard/.local/share/QGIS/QGIS3/profiles/rivm
src/app/main.cpp: 867: (main) [0ms] 	 -
src/app/qgscustomization.cpp: 943: (loadDefault) [4ms] Status path =
/Customization/status
src/app/qgscustomization.cpp: 944: (loadDefault) [0ms] status = 0
src/app/qgscustomization.cpp: 952: (loadDefault) [0ms] Default
customization not found in
/home/richard/bin/qgis/master/debug/share/qgis/resources/customization.ini
src/core/qgsfontutils.cpp: 277: (loadStandardTestFonts) [16ms] Test font
'QGIS Vera Sans' (Bold) loaded from testdata.qrc
'QGIS Vera Sans' (Roman) loaded from testdata.qrc
src/app/main.cpp: 1186: (main) [0ms] loading of qgis translation failed
/home/richard/bin/qgis/master/debug/share/qgis/i18n//qgis_en_US
src/app/main.cpp: 1200: (main) [0ms] loading of qt translation failed
/usr/share/qt5/translations/qt_en_US
src/core/qgsapplication.cpp: 1636: (setMaxThreads) [31ms] maxThreads: 6
src/core/qgsapplication.cpp: 1652: (setMaxThreads) [0ms] set QThreadPool
max thread count to 6
src/core/qgsruntimeprofiler.cpp: 54: (end) [0ms] PROFILE: User profile
manager - 0
src/core/qgsruntimeprofiler.cpp: 54: (end) [54ms] PROFILE:
qgisapp/startup/Setting up UI - 0.053
src/core/qgsruntimeprofiler.cpp: 54: (end) [25ms] PROFILE:
qgisapp/startup/Checking database - 0.025
src/core/qgsruntimeprofiler.cpp: 54: (end) [4ms] PROFILE:
qgisapp/startup/Creating theme folder - 0.001
src/core/qgsproviderregistry.cpp: 103: (init) [2ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins for provider plugins
src/core/qgsproviderregistry.cpp: 156: (init) [15ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libbasicauthmethod.so:
...invalid (no isProvider method)
src/core/qgsproviderregistry.cpp: 148: (init) [3ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libcoordinatecaptureplugin.so:
...invalid (has type method)
src/core/qgsproviderregistry.cpp: 148: (init) [9ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libevis.so:
src/providers/gdal/qgsgdalprovider.cpp: 2001:
(buildSupportedRasterFileFilterAndExtensions) [5ms] GDAL driver count: 202
src/providers/gdal/qgsgdalprovider.cpp: 2142:
(buildSupportedRasterFileFilterAndExtensions) [0ms] Raster filter list
built: All files (*);;GDAL/OGR VSIFileHandler (*.zip *.gz *.tar *.tar.gz
*.tgz *.ZIP *.GZ *.TAR *.TAR.GZ *.TGZ);;ACE2 (*.ace2 *.ACE2);;ARC
Digitized Raster Graphics (*.gen *.GEN);;ASCII Gridded XYZ (*.xyz
*.XYZ);;Arc/Info ASCII Grid (*.asc *.ASC);;Arc/Info Binary Grid (hdr.adf
HDR.ADF);;Arc/Info Export E00 GRID (*.e00 *.E00);;CALS  (*..cal *..ct1
*..CAL *..CT1);;DRDC COASP SAR Processor Raster (*.hdr *.HDR);;DTED
Elevation Raster (*.dt0 *.dt1 *.dt2 *.DT0 *.DT1 *.DT2);;ECRG TOC format
(*.xml *.XML);;ERMapper .ers Labelled (*.ers *.ERS);;ESRI .hdr Labelled
(*.bil *.BIL);;EUMETSAT Archive native  (*.nat *.NAT);;Envisat Image
Format (*.n1 *.N1);;Erdas Imagine Images  (*.img *.IMG);;FARSITE v.4
Landscape File  (*.lcp *.LCP);;GMT NetCDF Grid Format (*.nc
*.NC);;GRIdded Binary  (*.grb *.GRB);;GeoPackage (*.gpkg
*.GPKG);;GeoSoft Grid Exchange Format (*.gxf *.GXF);;GeoTIFF (*.tif
*.tiff *.TIF *.TIFF);;Geospatial PDF (*.pdf *.PDF);;Golden Software 7
Binary Grid  (*.grd *.GRD);;Golden Software ASCII Grid  (*.grd
*.GRD);;Golden Software Binary Grid  (*.grd *.GRD);;Graphics Interchange
Format  (*.gif *.GIF);;Ground-based SAR Applications Testbed File Format
 (*.gff *.GFF);;HF2/HFZ heightfield raster (*.hf2 *.HF2);;Hierarchical
Data Format Release 4 (*.hdf *.HDF);;Hierarchical Data Format Release 5
(*.hdf5 *.HDF5);;ILWIS Raster Map (*.mpr *.mpl *.MPR *.MPL);;IRIS data
*.JPG *.JPEG);;JPEG-2000 driver based on OpenJPEG library (*.jp2 *.j2k
*.JP2 *.J2K);;Japanese DEM  (*.mem *.MEM);;KOLOR Raw (*.kro
*.KRO);;Leveller heightfield (*.ter *.TER);;MBTiles (*.mbtiles
*.MBTILES);;MS Windows Device Independent Bitmap (*.bmp *.BMP);;Magellan
topo  (*.blx *.BLX);;NOAA NGS Geoid Height Grids (*.bin *.BIN);;NOAA
Vertical Datum .GTX (*.gtx *.GTX);;NTv2 Datum Grid Shift (*.gsb
*.GSB);;National Imagery Transmission Format (*.ntf *.NTF);;Network
Common Data Format (*.nc *.NC);;Northwood Classified Grid Format
.grc/.tab (*.grc *.GRC);;Northwood Numeric Grid Format .grd/.tab (*.grd
*.GRD);;PCIDSK Database File (*.pix *.PIX);;PCRaster Raster File (*.map
*.MAP);;Portable Network Graphics (*.png *.PNG);;Portable Pixmap Format
(*.pnm *.PNM);;R Object Data Store (*.rda *.RDA);;Raster Matrix Format
(*.rsw *.RSW);;Raster Product Format TOC format (*.toc
*.TOC);;Rasterlite (*.sqlite *.SQLITE);;SAGA GIS Binary Grid  (*.sdat
*.SDAT);;SDTS Raster (*.ddf *.DDF);;SGI Image File Format 1.0 (*.rgb
*.RGB);;SRTMHGT File Format (*.hgt *.HGT);;Snow Data Assimilation System
(*.hdr *.HDR);;Standard Raster Product  (*.img *.IMG);;Swedish Grid RIK
(*.rik *.RIK);;Terragen heightfield (*.ter *.TER);;USGS Optional ASCII
DEM  (*.dem *.DEM);;VTP .bt (Binary Terrain) 1.3 Format (*.bt
*.BT);;Vexcel MFF Raster (*.hdr *.HDR);;Virtual Raster (*.vrt *.ovr
*.VRT *.OVR);;WEBP (*.webp *.WEBP);;X11 PixMap Format (*.xpm
*.XPM);;ZMap Plus Grid (*.dat *.DAT)
src/providers/gdal/qgsgdalprovider.cpp: 2143:
(buildSupportedRasterFileFilterAndExtensions) [0ms] Raster extension
list built: vrt ovr tif tiff ntf toc xml img gff asc ddf dt0 dt1 dt2 png
jpg jpeg mem gif n1 xpm bmp pix map mprmpl rgb hgt ter ter nc nc hdf ers
jp2 j2k grb rsw nat rst grd grd grd hdr rda webp pdf sqlite mbtiles cal
ct1 pnm hdr bt lcp gtx gsb ACE2 hdr kro bil rik dem gxf hdf5 grd grc gen
img blx sdat xyz hf2 e00 dat bin ppi gpkg zip gz tar tar.gz tgz
src/core/qgsproviderregistry.cpp: 227: (init) [0ms] raster filters: All
files (*);;GDAL/OGR VSIFileHandler (*.zip *.gz *.tar *.tar.gz *.tgz
*.ZIP *.GZ *.TAR *.TAR.GZ *.TGZ);;ACE2 (*.ace2 *.ACE2);;ARC Digitized
Raster Graphics (*.gen *.GEN);;ASCII Gridded XYZ (*.xyz *.XYZ);;Arc/Info
src/core/qgsproviderregistry.cpp: 231: (init) [0ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libgdalprovider.so:
...loaded OK (73 file filters)
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libgeometrycheckerplugin.so:
src/core/qgsproviderregistry.cpp: 148: (init) [5ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libgeorefplugin.so:
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libgpsimporterplugin.so:
src/core/qgsproviderregistry.cpp: 156: (init) [4ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libidentcertauthmethod.so:
src/core/qgsproviderregistry.cpp: 156: (init) [7ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/liboauth2authmethod.so:
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libofflineeditingplugin.so:
src/providers/ogr/qgsogrprovider.cpp: 2578: (createFilters) [3ms] Driver
count: 77
src/providers/ogr/qgsogrprovider.cpp: 2954: (createFilters) [0ms]
Unknown driver OGR_SDTS for file filters.
src/providers/ogr/qgsogrprovider.cpp: 2954: (createFilters) [1ms]
Unknown driver Memory for file filters.
Unknown driver OGR_DODS for file filters.
Unknown driver OGR_OGDI for file filters.
Unknown driver GPSBabel for file filters.
Unknown driver OGR_PDS for file filters.
Unknown driver WFS for file filters.
Unknown driver AeronavFAA for file filters.
Unknown driver GFT for file filters.
Unknown driver Cloudant for file filters.
Unknown driver ElasticSearch for file filters.
Unknown driver Walk for file filters.
Unknown driver Carto for file filters.
Unknown driver AmigoCloud for file filters.
Unknown driver Selafin for file filters.
Unknown driver PLSCENES for file filters.
Unknown driver CSW for file filters.
Unknown driver HTTP for file filters.
src/providers/ogr/qgsogrprovider.cpp: 2961: (createFilters) [0ms]
myFileFilters: PCI Geomatics Database File (*.pix *.PIX);;Network Common
Data Format (*.nc *.NC);;Geospatial PDF (*.pdf *.PDF);;ESRI Shapefiles
(*.shp *.SHP);;Mapinfo File (*.mif *.tab *.MIF *.TAB);;S-57 Base file
(*.000 *.000);;Microstation DGN (*.dgn *.DGN);;VRT - Virtual Datasource
(*.vrt *.ovf *.VRT *.OVF);;EPIInfo .REC  (*.rec *.REC);;Atlas BNA (*.bna
*.BNA);;Comma Separated Value (*.csv *.CSV);;NAS - ALKIS (*.xml
*.XML);;Geography Markup Language [GML] (*.gml *.GML);;GPS eXchange
Format [GPX] (*.gpx *.GPX);;Keyhole Markup Language [KML] (*.kml *.kmz
*.KML *.KMZ);;GeoJSON (*.geojson *.GEOJSON);;INTERLIS 1 (*.itf *.xml
*.ili *.ITF *.XML *.ILI);;INTERLIS 2 (*.xtf *.xml *.ili *.XTF *.XML
*.ILI);;GMT ASCII Vectors (.gmt) (*.gmt *.GMT);;GeoPackage (*.gpkg
*.GPKG);;SQLite/SpatiaLite (*.sqlite *.db *.sqlite3 *.db3 *.s3db *.sl3
*.SQLITE *.DB *.SQLITE3 *.DB3 *.S3DB *.SL3);;WAsP (*.map
*.MAP);;X-Plane/Flightgear (apt.dat nav.dat fix.dat awy.dat APT.DAT
NAV.DAT FIX.DAT AWY.DAT);;AutoCAD DXF (*.dxf *.DXF);;Geoconcept (*.gxt
*.txt *.GXT *.TXT);;GeoRSS (*.xml *.XML);;GPSTrackMaker (*.gtm *.gtz
*.GTM *.GTZ);;Czech Cadastral Exchange Data Format (*.vfk
*.VFK);;PostgreSQL SQL dump (*.sql *.SQL);;OpenStreetMap (*.osm *.pbf
*.OSM *.PBF);;Special Use Airspace Format (*.sua *.SUA);;OpenAir Special
Use Airspace Format (*.txt *.TXT);;Hydrographic Transfer Format (*.htf
*.HTF);;Geomedia .mdb (*.mdb *.MDB);;EDIGEO (*.thf *.THF);;Scalable
Vector Graphics (*.svg *.SVG);;Idrisi Vector (.vct) (*.vct
*.VCT);;Arc/Info Generate (*.gen *.GEN);;SEG-P1 (*.seg *.seg1 *.sp1
*.SEG *.SEG1 *.SP1);;UKOOA P1/90 (*.uko *.ukooa *.UKO *.UKOOA);;SEG-Y
(*.sgy *.segy *.SGY *.SEGY);;MS Excel format (*.xls *.XLS);;Open
Document Spreadsheet (*.ods *.ODS);;MS Office Open XML spreadsheet
(*.xlsx *.XLSX);;Storage and eXchange Format (*.sxf *.SXF);;OpenJUMP JML
(*.jml *.JML);;VDV-451/VDV-452/INTREST Data Format (*.txt *.x10 *.TXT
*.X10);;Arc/Info ASCII Coverage (*.e00 *.E00);;
src/providers/ogr/qgsogrprovider.cpp: 2965: (createFilters) [0ms]
myFileFilters: Arc/Info ASCII Coverage (*.e00 *.E00);;Arc/Info Generate
(*.gen *.GEN);;Atlas BNA (*.bna *.BNA);;AutoCAD DXF (*.dxf *.DXF);;Comma
Separated Value (*.csv *.CSV);;Czech Cadastral Exchange Data Format
(*.vfk *.VFK);;EDIGEO (*.thf *.THF);;EPIInfo .REC  (*.rec *.REC);;ESRI
Shapefiles (*.shp *.SHP);;GMT ASCII Vectors (.gmt) (*.gmt *.GMT);;GPS
eXchange Format [GPX] (*.gpx *.GPX);;GPSTrackMaker (*.gtm *.gtz *.GTM
*.GTZ);;GeoJSON (*.geojson *.GEOJSON);;GeoPackage (*.gpkg
*.GPKG);;GeoRSS (*.xml *.XML);;Geoconcept (*.gxt *.txt *.GXT
*.TXT);;Geography Markup Language [GML] (*.gml *.GML);;Geomedia .mdb
(*.mdb *.MDB);;Geospatial PDF (*.pdf *.PDF);;Hydrographic Transfer
Format (*.htf *.HTF);;INTERLIS 1 (*.itf *.xml *.ili *.ITF *.XML
*.ILI);;INTERLIS 2 (*.xtf *.xml *.ili *.XTF *.XML *.ILI);;Idrisi Vector
(.vct) (*.vct *.VCT);;Keyhole Markup Language [KML] (*.kml *.kmz *.KML
*.KMZ);;MS Excel format (*.xls *.XLS);;MS Office Open XML spreadsheet
(*.xlsx *.XLSX);;Mapinfo File (*.mif *.tab *.MIF *.TAB);;Microstation
DGN (*.dgn *.DGN);;NAS - ALKIS (*.xml *.XML);;Network Common Data Format
(*.nc *.NC);;Open Document Spreadsheet (*.ods *.ODS);;OpenAir Special
Use Airspace Format (*.txt *.TXT);;OpenJUMP JML (*.jml
*.JML);;OpenStreetMap (*.osm *.pbf *.OSM *.PBF);;PCI Geomatics Database
File (*.pix *.PIX);;PostgreSQL SQL dump (*.sql *.SQL);;S-57 Base file
(*.000 *.000);;SEG-P1 (*.seg *.seg1 *.sp1 *.SEG *.SEG1 *.SP1);;SEG-Y
(*.sgy *.segy *.SGY *.SEGY);;SQLite/SpatiaLite (*.sqlite *.db *.sqlite3
*.db3 *.s3db *.sl3 *.SQLITE *.DB *.SQLITE3 *.DB3 *.S3DB *.SL3);;Scalable
Vector Graphics (*.svg *.SVG);;Special Use Airspace Format (*.sua
*.SUA);;Storage and eXchange Format (*.sxf *.SXF);;UKOOA P1/90 (*.uko
*.ukooa *.UKO *.UKOOA);;VDV-451/VDV-452/INTREST Data Format (*.txt *.x10
*.TXT *.X10);;VRT - Virtual Datasource (*.vrt *.ovf *.VRT *.OVF);;WAsP
(*.map *.MAP);;X-Plane/Flightgear (apt.dat nav.dat fix.dat awy.dat
APT.DAT NAV.DAT FIX.DAT AWY.DAT);;
src/providers/ogr/qgsogrprovider.cpp: 2985: (createFilters) [0ms]
myFileFilters: All files (*);;GDAL/OGR VSIFileHandler (*.zip *.gz *.tar
*.tar.gz *.tgz *.ZIP *.GZ *.TAR *.TAR.GZ *.TGZ);;Arc/Info ASCII Coverage
(*.e00 *.E00);;Arc/Info Generate (*.gen *.GEN);;Atlas BNA (*.bna
*.BNA);;AutoCAD DXF (*.dxf *.DXF);;Comma Separated Value (*.csv
*.CSV);;Czech Cadastral Exchange Data Format (*.vfk *.VFK);;EDIGEO
(*.thf *.THF);;EPIInfo .REC  (*.rec *.REC);;ESRI Shapefiles (*.shp
*.SHP);;GMT ASCII Vectors (.gmt) (*.gmt *.GMT);;GPS eXchange Format
[GPX] (*.gpx *.GPX);;GPSTrackMaker (*.gtm *.gtz *.GTM *.GTZ);;GeoJSON
(*.geojson *.GEOJSON);;GeoPackage (*.gpkg *.GPKG);;GeoRSS (*.xml
*.XML);;Geoconcept (*.gxt *.txt *.GXT *.TXT);;Geography Markup Language
[GML] (*.gml *.GML);;Geomedia .mdb (*.mdb *.MDB);;Geospatial PDF (*.pdf
*.PDF);;Hydrographic Transfer Format (*.htf *.HTF);;INTERLIS 1 (*.itf
*.xml *.ili *.ITF *.XML *.ILI);;INTERLIS 2 (*.xtf *.xml *.ili *.XTF
*.XML *.ILI);;Idrisi Vector (.vct) (*.vct *.VCT);;Keyhole Markup
Language [KML] (*.kml *.kmz *.KML *.KMZ);;MS Excel format (*.xls
*.XLS);;MS Office Open XML spreadsheet (*.xlsx *.XLSX);;Mapinfo File
(*.mif *.tab *.MIF *.TAB);;Microstation DGN (*.dgn *.DGN);;NAS - ALKIS
(*.xml *.XML);;Network Common Data Format (*.nc *.NC);;Open Document
Spreadsheet (*.ods *.ODS);;OpenAir Special Use Airspace Format (*.txt
*.TXT);;OpenJUMP JML (*.jml *.JML);;OpenStreetMap (*.osm *.pbf *.OSM
*.PBF);;PCI Geomatics Database File (*.pix *.PIX);;PostgreSQL SQL dump
(*.sql *.SQL);;S-57 Base file (*.000 *.000);;SEG-P1 (*.seg *.seg1 *.sp1
*.SEG *.SEG1 *.SP1);;SEG-Y (*.sgy *.segy *.SGY
*.SEGY);;SQLite/SpatiaLite (*.sqlite *.db *.sqlite3 *.db3 *.s3db *.sl3
*.SQLITE *.DB *.SQLITE3 *.DB3 *.S3DB *.SL3);;Scalable Vector Graphics
(*.svg *.SVG);;Special Use Airspace Format (*.sua *.SUA);;Storage and
eXchange Format (*.sxf *.SXF);;UKOOA P1/90 (*.uko *.ukooa *.UKO
*.UKOOA);;VDV-451/VDV-452/INTREST Data Format (*.txt *.x10 *.TXT
*.X10);;VRT - Virtual Datasource (*.vrt *.ovf *.VRT *.OVF);;WAsP (*.map
src/core/qgsproviderregistry.cpp: 215: (init) [0ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libogrprovider.so:
...loaded OK (50 file filters)
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libpkcs12authmethod.so:
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libpkipathsauthmethod.so:
src/core/qgsproviderregistry.cpp: 148: (init) [7ms] Checking
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libtopolplugin.so:
src/providers/wfs/qgswfsutils.cpp: 212: (init) [8ms] Keep-alive
mechanism works
src/core/qgsproviderregistry.cpp: 503: (createProviderLibrary) [3ms]
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libdb2provider.so
src/core/qgsproviderregistry.cpp: 503: (createProviderLibrary) [0ms]
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libwfsprovider.so
src/core/qgsdataitemproviderregistry.cpp: 103:
(QgsDataItemProviderRegistry) [0ms]
does not have dataCapabilities
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libarcgisfeatureserverprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libarcgismapserverprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libdelimitedtextprovider.so
Library name is
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libgeonodeprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libgpxprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libmdalprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libmssqlprovider.so
Library name is
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libowsprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libpostgresprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libspatialiteprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libvirtuallayerprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libwcsprovider.so
Library name is
/home/richard/bin/qgis/master/debug/lib/qgis/plugins/libwmsprovider.so
src/core/auth/qgsauthmanager.cpp: 143: (init) [0ms] Initializing QCA...
src/core/auth/qgsauthmanager.cpp: 146: (init) [0ms] QCA initialized.
src/core/auth/qgsauthmanager.cpp: 149: (init) [4ms] QCA Plugin
Diagnostics Context: Checking Qt static plugins:
  (none)
Checking Qt Library Path:
  (No 'crypto' subdirectory)
Checking Qt Library Path: /usr/lib/x86_64-linux-gnu/qt5/plugins
Checking Qt Library Path: /home/richard/bin/qgis/master/debug/bin
Checking Qt Library Path: /usr/lib/x86_64-linux-gnu/qca-qt5
  libqca-cyrus-sasl.so: (class: saslPlugin) loaded as qca-cyrus-sasl
  libqca-gnupg.so: (class: gnupgPlugin) loaded as qca-gnupg
  libqca-logger.so: (class: loggerPlugin) loaded as qca-logger
  libqca-ossl.so: (class: opensslPlugin) loaded as qca-ossl
  libqca-softstore.so: (class: softstorePlugin) loaded as qca-softstore
src/core/auth/qgsauthmanager.cpp: 153: (init) [0ms] QCA supports:
random,md5,sha1,keystorelist,sasl,pgpkey,openpgp,log,sha0,ripemd160,md4,sha224,sha256,sha384,sha512,hmac(md5),hmac(sha1),hmac(sha224),hmac(sha256),hmac(sha384),hmac(sha512),hmac(ripemd160),aes128-ecb,aes128-cfb,aes128-cbc,aes128-cbc-pkcs7,aes128-ofb,aes128-ctr,aes192-ecb,aes192-cfb,aes192-cbc,aes192-cbc-pkcs7,aes192-ofb,aes192-ctr,aes256-ecb,aes256-cbc,aes256-cbc-pkcs7,aes256-cfb,aes256-ofb,aes256-ctr,blowfish-ecb,blowfish-cbc-pkcs7,blowfish-cbc,blowfish-cfb,blowfish-ofb,tripledes-ecb,tripledes-cbc,des-ecb,des-ecb-pkcs7,des-cbc,des-cbc-pkcs7,des-cfb,des-ofb,cast5-ecb,cast5-cbc,cast5-cbc-pkcs7,cast5-cfb,cast5-ofb,pbkdf1(sha1),pbkdf2(sha1),pkey,dlgroup,rsa,dsa,dh,cert,csr,crl,certcollection,pkcs12,tls,cms,ca
src/core/auth/qgsauthmanager.cpp: 163: (init) [2ms] Prioritizing
qca-ossl over all other QCA providers...
src/core/auth/qgsauthmanager.cpp: 177: (init) [0ms] QCA provider
priorities: qca-cyrus-sasl:1, qca-gnupg:1, qca-logger:1, qca-ossl:0,
qca-softstore:1
src/core/auth/qgsauthmanager.cpp: 179: (init) [0ms] Populating auth
method registry
src/core/auth/qgsauthmethodregistry.cpp: 66: (QgsAuthMethodRegistry)
[0ms] Checking for auth method plugins in:
src/core/auth/qgsauthmanager.cpp: 184: (init) [0ms] Authentication
methods found: Basic, Identity-Cert, OAuth2, PKI-PKCS#12, PKI-Paths
src/core/auth/qgsauthmethodregistry.cpp: 289: (authMethod) [0ms] Auth
method library name is
src/core/auth/qgsauthmethodregistry.cpp: 311: (authMethod) [0ms]
Instantiated the auth method plugin: Basic
Instantiated the auth method plugin: Identity-Cert
src/core/auth/qgsauthmethodregistry.cpp: 311: (authMethod) [1ms]
Instantiated the auth method plugin: OAuth2
Instantiated the auth method plugin: PKI-PKCS#12
Instantiated the auth method plugin: PKI-Paths
src/core/auth/qgsauthmanager.cpp: 201: (init) [0ms] Auth database path:
/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/qgis-auth.db
src/core/auth/qgsauthmanager.cpp: 205: (init) [0ms] Auth db directory
path: /home/richard/.local/share/QGIS/QGIS3/profiles/rivm
src/core/auth/qgsauthmanager.cpp: 230: (init) [0ms] Auth db exists and
has data
src/core/auth/qgsauthmanager.cpp: 362: (createCertTables) [0ms] Creating
cert tables in auth db
src/core/auth/qgsauthmanager.cpp: 927: (updateConfigAuthMethods) [1ms]
Synching existing auth config and their auth methods
src/core/auth/qgsauthmanager.cpp: 936: (updateConfigAuthMethods) [0ms]
Stored auth config/methods:
src/core/auth/qgsauthmanager.cpp: 2545: (rebuildCaCertsCache) [39ms]
Rebuild of CA certs cache SUCCEEDED
src/core/auth/qgsauthmanager.cpp: 2750: (rebuildCertTrustCache) [0ms]
Rebuild of cert trust policy cache SUCCEEDED
src/core/auth/qgsauthmanager.cpp: 2818: (rebuildTrustedCaCertsCache)
[4ms] Rebuilt trusted cert authorities cache
src/core/auth/qgsauthmanager.cpp: 2302: (rebuildIgnoredSslErrorCache)
[0ms] Rebuild of ignored SSL errors cache SAME AS BEFORE
src/core/auth/qgsauthmanager.cpp: 2169: (dumpIgnoredSslErrorsCache_)
[0ms] Ignored SSL errors cache EMPTY
src/core/auth/qgsauthmanager.cpp: 1666: (initSslCaches) [0ms] Init of
SSL caches SUCCEEDED
src/core/qgsnetworkaccessmanager.cpp: 339: (setupDefaultProxyAndCache)
[32ms] setting default proxy
src/core/qgsnetworkaccessmanager.cpp: 163: (setFallbackProxyAndExcludes)
[0ms] proxy settings: (type:Socks5Proxy host: proxy.svc.cal-net.nl:3128,
user:, password:not set
src/core/qgsnetworkaccessmanager.cpp: 390: (setupDefaultProxyAndCache)
[0ms] cacheDirectory:
/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/cache/
src/core/qgsnetworkaccessmanager.cpp: 391: (setupDefaultProxyAndCache)
[0ms] maximumCacheSize: 52428800
src/app/qgisappstylesheet.cpp: 210: (setActiveValues) [0ms] Style name:
fusion
src/app/qgisappstylesheet.cpp: 59: (defaultOptions) [1ms] fontPointSize: 11
src/app/qgisappstylesheet.cpp: 79: (defaultOptions) [0ms] fontFamily:
Cantarell
src/app/qgisappstylesheet.cpp: 98: (buildStyleSheet) [0ms] fontPointSize: 11
src/app/qgisappstylesheet.cpp: 102: (buildStyleSheet) [0ms] fontFamily:
Cantarell
src/app/qgisappstylesheet.cpp: 124: (buildStyleSheet) [0ms]
groupBoxCustom: 0
src/app/qgisappstylesheet.cpp: 188: (buildStyleSheet) [0ms] Stylesheet
built: * { font: 11pt "Cantarell"} QGroupBox{color:
rgb(60,60,60);font-weight: bold;} QListWidget#mOptionsListWidget {
background-color: rgb(69, 69, 69, 0);    outline:
0;}QFrame#mOptionsListFrame {    background-color: rgb(69, 69, 69,
220);}QListWidget#mOptionsListWidget::item {    color: white;
padding: 3px;}QListWidget#mOptionsListWidget::item::selected {    color:
black;    background-color:palette(Window);    padding-right:
0px;}QTableView {selection-background-color: #308cc6;selection-color:
#ffffff;}
src/core/qgsruntimeprofiler.cpp: 54: (end) [3ms] PROFILE:
qgisapp/startup/Building style sheet - 0.004
src/core/qgsscalecalculator.cpp: 40: (setMapUnits) [0ms] Map units set to 9
src/core/qgsellipsoidutils.cpp: 105: (ellipsoidParameters) [1ms]
setEllipsoid: no row in tbl_ellipsoid for acronym 'NONE'
src/gui/qgsmapcanvas.cpp: 481: (refresh) [0ms] CANVAS refresh - invalid
settings -> nothing to do
qgisapp/startup/Creating map canvas - 0.001
src/core/qgsnetworkaccessmanager.cpp: 185: (createRequest) [1ms] Adding
trusted CA certs to request
src/core/qgsnetworkaccessmanager.cpp: 223: (createRequest) [2ms] Created
[reply:56025dd4b820]
qgisapp/startup/Welcome page - 0.003
qgisapp/startup/Message bar - 0
qgisapp/startup/User input dock - 0
src/core/qgsruntimeprofiler.cpp: 54: (end) [1ms] PROFILE:
qgisapp/startup/Layer tree - 0.001
src/core/qgsruntimeprofiler.cpp: 54: (end) [2ms] PROFILE:
qgisapp/startup/Undo dock - 0.002
qgisapp/startup/Advanced digitize panel - 0.003
src/core/qgsruntimeprofiler.cpp: 54: (end) [11ms] PROFILE:
qgisapp/startup/Stats dock - 0.011
qgisapp/startup/Bookmarks widget - 0.004
qgisapp/startup/Snapping utils - 0
Warning: QSqlQuery::prepare: database not open
Stacktrace (piped through c++filt):
/home/richard/bin/qgis/master/debug/bin/qgis(+0xbd7c)[0x56025bbded7c]
/home/richard/bin/qgis/master/debug/bin/qgis(+0xc1f4)[0x56025bbdf1f4]
/usr/lib/x86_64-linux-gnu/libQt5Core.so.5(+0x93aad)[0x7fb351ee9aad]
/usr/lib/x86_64-linux-gnu/libQt5Core.so.5(QMessageLogger::warning(char
const*, ...) const+0xac)[0x7fb351eea86c]
/usr/lib/x86_64-linux-gnu/libQt5Sql.so.5(QSqlQuery::prepare(QString
const&)+0x1fc)[0x7fb35c530f7c]
/home/richard/bin/qgis/master/debug/lib/libqgis_core.so.3.3.0(QgsUserProfile::alias()
const+0x1b7)[0x7fb358db076d]
/home/richard/bin/qgis/master/debug/lib/libqgis_app.so.3.3.0(QgisApp::refreshProfileMenu()+0x22c)[0x7fb35b5c720e]
/home/richard/bin/qgis/master/debug/lib/libqgis_app.so.3.3.0(QgisApp::createProfileMenu()+0x9e)[0x7fb35b5c7732]
/home/richard/bin/qgis/master/debug/lib/libqgis_app.so.3.3.0(QgisApp::createMenus()+0x643)[0x7fb35b5c6d9d]
/home/richard/bin/qgis/master/debug/lib/libqgis_app.so.3.3.0(QgisApp::functionProfile(void
(QgisApp::*)(), QgisApp*, QString const&)+0x7c)[0x7fb35b61b684]
/home/richard/bin/qgis/master/debug/lib/libqgis_app.so.3.3.0(QgisApp::QgisApp(QSplashScreen*,
bool, bool, QString const&, QString const&, QWidget*,
QFlags<Qt::WindowType>)+0x2db4)[0x7fb35b5b1fdc]
/home/richard/bin/qgis/master/debug/bin/qgis(+0x1160b)[0x56025bbe460b]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7fb3510092e1]
/home/richard/bin/qgis/master/debug/bin/qgis(_start+0x2a)[0x56025bbdd16a]
src/core/qgsmessagelog.cpp: 27: (logMessage) [5ms] 2018-07-03T12:06:58
Qt[1] QSqlQuery::prepare: database not open
Warning: QSqlDatabasePrivate::addDatabase: duplicate connection name
'userprofile', old connection removed.
/usr/lib/x86_64-linux-gnu/libQt5Sql.so.5(+0x19485)[0x7fb35c537485]
/usr/lib/x86_64-linux-gnu/libQt5Sql.so.5(QSqlDatabase::addDatabase(QString
const&, QString const&)+0x1c)[0x7fb35c537d2c]
const+0xc0)[0x7fb358db0676]
src/core/qgsmessagelog.cpp: 27: (logMessage) [2ms] 2018-07-03T12:06:58
Qt[1] QSqlDatabasePrivate::addDatabase: duplicate connection name
src/core/qgsmessagelog.cpp: 27: (logMessage) [3ms] 2018-07-03T12:06:58
qgisapp/startup/Create menus - 0.011
qgisapp/startup/Create actions - 0
qgisapp/startup/Create action group - 0
src/core/qgsruntimeprofiler.cpp: 54: (end) [9ms] PROFILE:
qgisapp/startup/Toolbars - 0.009
src/core/qgsruntimeprofiler.cpp: 54: (end) [6ms] PROFILE:
qgisapp/startup/Status bar - 0.006
src/core/qgscoordinatereferencesystem.cpp: 466: (loadFromDatabase) [1ms]
load CRS from
/home/richard/bin/qgis/master/debug/share/qgis/resources/srs.db where
srs_id is 3452
src/core/qgsscalecalculator.cpp: 46: (mapUnits) [2ms] Map units returned
as 9
src/core/qgsscalecalculator.cpp: 46: (mapUnits) [3ms] Map units returned
as 9
src/core/qgsdistancearea.cpp: 834: (convertAreaMeasurement) [0ms]
Converted area of 0 <unknown> to 0 square meters
src/core/qgsdistancearea.cpp: 834: (convertAreaMeasurement) [1ms]
qgisapp/startup/Create canvas tools - 0.009
src/gui/qgsmapcanvas.cpp: 481: (refresh) [4ms] CANVAS refresh - invalid
src/gui/qgsmapcanvas.cpp: 481: (refresh) [1ms] CANVAS refresh - invalid
qgisapp/startup/Init Layer tree view - 0.005
qgisapp/startup/Create overview - 0
qgisapp/startup/Create map tips - 0
src/app/qgsdecorationitem.cpp: 78: (setName) [0ms] name=Copyright Label
nameconfig=CopyrightLabel nametrans=Copyright Label
src/app/qgsdecorationitem.cpp: 78: (setName) [1ms] name=North Arrow
nameconfig=NorthArrow nametrans=North Arrow
src/app/qgsdecorationitem.cpp: 78: (setName) [0ms] name=Scale Bar
nameconfig=ScaleBar nametrans=Scale Bar
src/app/qgsdecorationitem.cpp: 78: (setName) [0ms] name=Grid
nameconfig=Grid nametrans=Grid
src/app/qgsdecorationitem.cpp: 78: (setName) [0ms] name=Layout Extent
nameconfig=LayoutExtent nametrans=Layout Extent
qgisapp/startup/Create decorations - 0.001
src/core/qgsruntimeprofiler.cpp: 54: (end) [28ms] PROFILE:
qgisapp/startup/Read settings - 0.028
qgisapp/startup/Update project from templates - 0
qgisapp/startup/Legend layer selection changed - 0
qgisapp/startup/Initialize 3D support - 0
qgisapp/startup/Initialize native processing - 0.001
qgisapp/startup/Initialize layouts support - 0.003
qgisapp/startup/Update recent project paths - 0
src/core/qgsruntimeprofiler.cpp: 54: (end) [45ms] PROFILE:
qgisapp/startup/Plugin manager - 0.045
qgisapp/startup/Layer Style dock - 0.004
src/gui/qgsgui.cpp: 86: (enableAutoGeometryRestore) [3ms] WARNING: No
object name set. Best for it to be set objectName when using
QgsGui::enableAutoGeometryRestore
qgisapp/startup/Snapping dialog - 0.004
src/gui/qgsmapcanvas.cpp: 481: (refresh) [3ms] CANVAS refresh - invalid
[15ms] load CRS from
lower(auth_name||':'||auth_id) is epsg:4326
src/gui/qgsmapcanvas.cpp: 481: (refresh) [5ms] CANVAS refresh - invalid
src/core/qgsmessagelog.cpp: 27: (logMessage) [1ms] 2018-07-03T12:06:58
[0] QGIS starting…
src/core/qgsnetworkaccessmanager.cpp: 86: (queryProxy) [17ms] requesting
system proxy for query https://version.qgis.org/version.txt
src/core/qgsnetworkaccessmanager.cpp: 91: (queryProxy) [0ms] using
system proxy proxy.svc.cal-net.nl:3128 for query
src/app/qgisapp.cpp: 9903: (loadPythonSupport) [1ms] load library
/home/richard/bin/qgis/master/debug/lib/qgispython (3.3.0)
src/core/qgsmessagelog.cpp: 27: (logMessage) [324ms] 2018-07-03T12:06:59
[0] Python support ENABLED :-)
src/app/qgspluginregistry.cpp: 603: (checkCppPlugin) [1ms] Failed to get
name, description, category or type for
src/app/qgspluginregistry.cpp: 603: (checkCppPlugin) [0ms] Failed to get
src/app/qgspluginregistry.cpp: 520: (restoreSessionPlugins) [5ms]
Loading python plugins
src/core/qgsmessagelog.cpp: 27: (logMessage) [19ms] 2018-07-03T12:06:59
Python warning[1]
warning:/home/richard/bin/qgis/master/debug/share/qgis/python/qgis/utils.py:674:
PendingDeprecationWarning: the imp module is deprecated in favour of
importlib; see the module's documentation for alternative uses
  mod = _builtin_import(name, globals, locals, fromlist, level)
traceback:  File "<string>", line 1, in <module>
  File
"/home/richard/bin/qgis/master/debug/share/qgis/python/qgis/utils.py",
line 337, in startPlugin
    plugins[packageName] = package.classFactory(iface)
  File
"/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/python/plugins/nominatim_locator_filter/__init__.py",
line 10, in classFactory
    from .nominatimfilter import NominatimFilterPlugin
  File
line 674, in _import
  File "<frozen importlib._bootstrap>", line 969, in _find_and_load
  File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 673, in exec_module
  File "<frozen importlib._bootstrap>", line 222, in
_call_with_frames_removed
  File
"/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/python/plugins/nominatim_locator_filter/nominatimfilter.py",
line 6, in <module>
    from . networkaccessmanager import NetworkAccessManager,
RequestsException
  File
  File
"/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/python/plugins/nominatim_locator_filter/networkaccessmanager.py",
line 21, in <module>
    from future import standard_library
  File
  File "<frozen importlib._bootstrap>", line 1016, in _handle_fromlist
  File
"/usr/lib/python3/dist-packages/future/standard_library/__init__.py",
line 66, in <module>
    import imp
  File
src/core/qgsmessagelog.cpp: 27: (logMessage) [45ms] 2018-07-03T12:06:59
Plugins[0] Loaded Nominatim Locator Filter (package:
nominatim_locator_filter)
src/core/qgsmessagelog.cpp: 27: (logMessage) [452ms] 2018-07-03T12:06:59
Plugins[0] Loaded PDOK services plugin (package: pdokservicesplugin)
src/core/qgsmessagelog.cpp: 27: (logMessage) [343ms] 2018-07-03T12:06:59
Python warning[1]
DeprecationWarning:
IPython.utils.signatures backport for Python 2 is deprecated in IPython
6, which only supports Python 3
  File
  File
"/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/python/plugins/qgis2web/__init__.py",
line 28, in classFactory
    from .qgis2web import Qgis2Web
  File
  File
"/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/python/plugins/qgis2web/qgis2web.py",
line 30, in <module>
    from qgis2web.maindialog import MainDialog
  File
  File
"/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/python/plugins/qgis2web/maindialog.py",
line 64, in <module>
    from . import utils
  File
  File
"/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/python/plugins/qgis2web/utils.py",
line 47, in <module>
    import processing
  File
  File
"/home/richard/bin/qgis/master/debug/share/qgis/python/plugins/processing/__init__.py",
line 29, in <module>
    from processing.tools.general import *              # NOQA
  File
  File
"/home/richard/bin/qgis/master/debug/share/qgis/python/plugins/processing/tools/general.py",
line 39, in <module>
    from processing.core.Processing import Processing
  File
  File
"/home/richard/bin/qgis/master/debug/share/qgis/python/plugins/processing/core/Processing.py",
line 58, in <module>
    from processing.algs.qgis.QgisAlgorithmProvider import
QgisAlgorithmProvider  # NOQA
  File
  File
"/home/richard/bin/qgis/master/debug/share/qgis/python/plugins/processing/algs/qgis/QgisAlgorithmProvider.py",
line 36, in <module>
    import plotly  # NOQA
  File
  File "/usr/lib/python3/dist-packages/plotly/__init__.py", line 31, in
<module>
    from plotly import (plotly, graph_objs, grid_objs, tools, utils,
session,
  File
  File "/usr/lib/python3/dist-packages/plotly/plotly/__init__.py", line
10, in <module>
    from . plotly import (
  File
  File "/usr/lib/python3/dist-packages/plotly/plotly/plotly.py", line
31, in <module>
    from plotly import exceptions, tools, utils, version, files
  File
  File "/usr/lib/python3/dist-packages/plotly/tools.py", line 73, in
<module>
    import IPython
  File
  File
"/home/richard/.local/lib/python3.5/site-packages/IPython/__init__.py",
line 55, in <module>
    from .terminal.embed import embed
  File
  File
"/home/richard/.local/lib/python3.5/site-packages/IPython/terminal/embed.py",
line 14, in <module>
    from IPython.core.magic import Magics, magics_class, line_magic
  File
  File
"/home/richard/.local/lib/python3.5/site-packages/IPython/core/magic.py",
line 20, in <module>
    from IPython.core import oinspect
  File
  File
"/home/richard/.local/lib/python3.5/site-packages/IPython/core/oinspect.py",
    from IPython.lib.pretty import pretty
  File
  File
"/home/richard/.local/lib/python3.5/site-packages/IPython/lib/pretty.py",
line 91, in <module>
    from IPython.utils.signatures import signature
  File
Warning: libpng warning: iCCP: known incorrect sRGB profile
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(+0x198ca5)[0x7fb3550c3ca5]
/usr/lib/x86_64-linux-gnu/libpng16.so.16(png_chunk_warning+0x40)[0x7fb34fe3ce20]
/usr/lib/x86_64-linux-gnu/libpng16.so.16(+0x8c95)[0x7fb34fe3bc95]
/usr/lib/x86_64-linux-gnu/libpng16.so.16(+0x19d71)[0x7fb34fe4cd71]
/usr/lib/x86_64-linux-gnu/libpng16.so.16(png_read_info+0x376)[0x7fb34fe421d6]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(+0x199a95)[0x7fb3550c4a95]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(+0x19a055)[0x7fb3550c5055]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(+0x19b9b9)[0x7fb3550c69b9]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(+0x15ba4b)[0x7fb355086a4b]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(QImageReader::read(QImage*)+0x2f)[0x7fb3550872ef]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(QImageReader::read()+0x34)[0x7fb3550873a4]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(QPixmapIconEngine::addFile(QString
const&, QSize const&, QIcon::Mode, QIcon::State)+0x1e8)[0x7fb3550a7cb8]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(QIcon::addFile(QString const&,
QSize const&, QIcon::Mode, QIcon::State)+0x8b)[0x7fb3550ab31b]
/usr/lib/x86_64-linux-gnu/libQt5Gui.so.5(QIcon::QIcon(QString
const&)+0x3a)[0x7fb3550ab5da]
/usr/lib/python3/dist-packages/PyQt5/QtGui.cpython-35m-x86_64-linux-gnu.so(+0x12fd0a)[0x7fb2c5686d0a]
/usr/lib/python3/dist-packages/sip.cpython-35m-x86_64-linux-gnu.so(+0xa193)[0x7fb2c5f55193]
src/core/qgsmessagelog.cpp: 27: (logMessage) [419ms] 2018-07-03T12:07:00
Qt[1] libpng warning: iCCP: known incorrect sRGB profile
src/core/qgsmessagelog.cpp: 27: (logMessage) [12ms] 2018-07-03T12:07:00
src/core/qgsmessagelog.cpp: 27: (logMessage) [5ms] 2018-07-03T12:07:00
Plugins[0] Loaded qgis2web (package: qgis2web)
src/core/qgsmessagelog.cpp: 27: (logMessage) [36ms] 2018-07-03T12:07:00
Plugins[0] Loaded PDOK Locatieserver Locator Filter (package:
pdok_locatieserver_locator_filter)
src/core/qgsmessagelog.cpp: 27: (logMessage) [53ms] 2018-07-03T12:07:00
Plugins[0] Loaded IPyConsole (package: IPyConsole)
src/core/qgsmessagelog.cpp: 27: (logMessage) [148ms] 2018-07-03T12:07:00
Plugins[0] Loaded MetaSearch Catalog Client (package: MetaSearch)
src/core/qgsmessagelog.cpp: 27: (logMessage) [199ms] 2018-07-03T12:07:00
Processing[2] Problem with SAGA installation: SAGA was not found or is
not correctly installed
src/gui/qgsmapcanvas.cpp: 481: (refresh) [105ms] CANVAS refresh -
invalid settings -> nothing to do
src/core/qgsmessagelog.cpp: 27: (logMessage) [193ms] 2018-07-03T12:07:01
Plugins[0] Loaded Processing (package: processing)
src/core/qgsmessagelog.cpp: 27: (logMessage) [38ms] 2018-07-03T12:07:01
Plugins[0] Loaded DB Manager (package: db_manager)
src/app/qgspluginregistry.cpp: 581: (restoreSessionPlugins) [18ms]
Plugin loading completed
src/core/qgspythonrunner.cpp: 32: (run) [1ms] Running import
pyplugin_installer
src/core/qgspythonrunner.cpp: 32: (run) [5ms] Running
pyplugin_installer.initPluginInstaller()
src/core/qgsruntimeprofiler.cpp: 54: (end) [136ms] PROFILE:
qgisapp/startup/initPluginInstaller - 0.142
src/core/qgsruntimeprofiler.cpp: 54: (end) [10ms] PROFILE:
qgisapp/startup/Restore window state - 0.006
qgisapp/startup/Update customiziation on main window - 0.001
src/core/symbology/qgssymbollayerutils.cpp: 3767: (svgSymbolNameToPath)
[2ms] SvgPath: /home/richard/bin/qgis/master/debug/share/qgis/svg
src/core/symbology/qgssymbollayerutils.cpp: 3775: (svgSymbolNameToPath)
[0ms] Alternative svg path:
/home/richard/bin/qgis/master/debug/share/qgis/svg/shopping/shopping_pet2.svg
src/core/symbology/qgssymbollayerutils.cpp: 3778: (svgSymbolNameToPath)
[0ms] Svg found in alternative path
[1ms] SvgPath: /home/richard/bin/qgis/master/debug/share/qgis/svg
[23ms] SvgPath: /home/richard/bin/qgis/master/debug/share/qgis/svg
/home/richard/bin/qgis/master/debug/share/qgis/svg/backgrounds/background_square_rounded.svg
/home/richard/bin/qgis/master/debug/share/qgis/svg/symbol/disability_accessibility2.svg
[5ms] SvgPath: /home/richard/bin/qgis/master/debug/share/qgis/svg
/home/richard/bin/qgis/master/debug/share/qgis/svg/transport/transport_airport.svg
[0ms] SvgPath: /home/richard/bin/qgis/master/debug/share/qgis/svg
/home/richard/bin/qgis/master/debug/share/qgis/svg/accommodation/accommodation_camping.svg
src/core/qgsruntimeprofiler.cpp: 54: (end) [7ms] PROFILE:
qgisapp/startup/Populate saved styles - 0.039
src/core/qgsmessagelog.cpp: 27: (logMessage) [0ms] 2018-07-03T12:07:01
[0] Application state:
QGIS_PREFIX_PATH env var:
Prefix:		/home/richard/bin/qgis/master/debug
Plugin Path:		/home/richard/bin/qgis/master/debug/lib/qgis/plugins
Package Data Path:	/home/richard/bin/qgis/master/debug/share/qgis
Active Theme Name:	default
Active Theme Path:
/home/richard/bin/qgis/master/debug/share/qgis/resources/themes/default/icons/
Default Theme Path:	:/images/themes/default/
SVG Search Paths:	/home/richard/bin/qgis/master/debug/share/qgis/svg/
		/home/richard/.local/share/QGIS/QGIS3/profiles/rivm/svg/
		/home/richard/git/qgisqt/images/svg/
		/images/svg/
User DB Path:
/home/richard/bin/qgis/master/debug/share/qgis/resources/qgis.db
Auth DB Path:
src/core/qgsmessagelog.cpp: 27: (logMessage) [1ms] 2018-07-03T12:07:01
[0] QGIS Ready!
[29ms] load CRS from
lower(auth_name||':'||auth_id) is epsg:3857
src/core/qgsdataitem.cpp: 256: (populate) [25ms] mPath = favorites:
src/providers/gdal/qgsgdaldataitems.cpp: 138: (dataItem) [0ms] thePath =
/home/richard/z/18/rivm
src/providers/gdal/qgsgdaldataitems.cpp: 183: (dataItem) [0ms] path=
/home/richard/z/18/rivm tmpPath= /home/richard/z/18/rivm name= rivm
suffix=  vsiPrefix=
src/providers/ogr/qgsogrdataitems.cpp: 490: (dataItem) [0ms] thePath:
src/providers/ogr/qgsogrdataitems.cpp: 535: (dataItem) [0ms] thePath=
suffix=  vsiPrefix=
src/core/qgsdataitem.cpp: 327: (populate) [1ms] mPath = favorites:
src/core/qgsdataitem.cpp: 463: (addChildItem) [0ms] path = favorites:
add child #0 - /home/richard/z/18/rivm - 1
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item favorites: set
state 0 -> 2
src/providers/db2/qgsdb2provider.cpp: 1729: (dataItem) [0ms] DB2:
Browser Panel; data item detected.
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = DB2:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item DB2: set state 0 -> 1
src/core/qgsbrowsermodel.cpp: 143: (addRootItems) [0ms] Add new top
level item : DB2
src/providers/wfs/qgswfsdataitems.cpp: 281: (createDataItem) [0ms] WFS
path =
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = wfs:
src/core/qgsdataitem.cpp: 279: (runCreateChildren) [0ms]
[thread:0x5602645be510] path = DB2:
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = wfs:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item wfs: set state 0 -> 2
level item : WFS
src/core/qgsdataitem.cpp: 283: (runCreateChildren) [0ms]
[thread:0x5602645be510] 0 children created in 0 ms
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = arcgisfeatureserver:
src/core/qgsdataitem.cpp: 293: (runCreateChildren) [0ms]
[thread:0x5602645be510] finished path DB2:: 0 children
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = arcgisfeatureserver:
arcgisfeatureserver: set state 0 -> 2
level item : ArcGisFeatureServer
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = arcgismapserver:
src/core/qgsowsconnection.cpp: 41: (QgsOwsConnection) [0ms] theConnName
= ESRI World Boundaries
src/core/qgsowsconnection.cpp: 78: (QgsOwsConnection) [0ms] encoded uri:
'url=http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer'.
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = arcgismapserver:
arcgismapserver: add child #0 - ESRI World Boundaries - 0
src/core/qgsdataitem.cpp: 560: (setState) [1ms] item arcgismapserver:
set state 0 -> 2
level item : ArcGisMapServer
src/providers/geonode/qgsgeonodedataitems.cpp: 262: (createDataItem)
[0ms] thePath =
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = geonode:
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = geonode:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item geonode: set state
0 -> 2
level item : GeoNode
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = mssql:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item mssql: set state 0 -> 1
level item : MSSQL
[thread:0x5602645be510] path = mssql:
src/providers/ogr/qgsgeopackagedataitems.cpp: 45: (createDataItem) [0ms]
path =
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = gpkg:
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = gpkg:
[thread:0x5602645be510] finished path mssql:: 0 children
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item gpkg: set state 0 -> 2
level item : GeoPackage
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = ows:
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = ows:
src/core/qgsdataitem.cpp: 463: (addChildItem) [0ms] path = ows: add
child #0 - wms-cal-net - 0
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item ows: set state 0 -> 2
level item : OWS
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = pg:
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = pg:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item pg: set state 0 -> 2
level item : PostGIS
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = spatialite:
src/core/qgsdataitem.cpp: 327: (populate) [1ms] mPath = spatialite:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item spatialite: set
state 0 -> 2
level item : SpatiaLite
src/providers/wcs/qgswcsdataitems.cpp: 281: (dataItem) [0ms] thePath =
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = wcs:
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = wcs:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item wcs: set state 0 -> 2
level item : WCS
src/providers/wms/qgswmsdataitems.cpp: 422: (createDataItem) [0ms] path =
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = wms:
= wms-cal-net
'dpiMode=7&url=http://wms.cal-net.nl/'.
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = wms:
src/core/qgsdataitem.cpp: 463: (addChildItem) [0ms] path = wms: add
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item wms: set state 0 -> 2
level item : WMS/WMTS
src/core/qgsdataitem.cpp: 256: (populate) [0ms] mPath = xyz:
xyz:/ArcgisWorldImagery set state 0 -> 2
xyz:/ArcgisWorldTopo set state 0 -> 2
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item xyz:/Google
Satellite set state 0 -> 2
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item xyz:/Google Terrain
set state 0 -> 2
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item xyz:/OpenStreetMap
set state 0 -> 2
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item xyz:/osm set state
0 -> 2
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = xyz:
src/core/qgsdataitem.cpp: 463: (addChildItem) [0ms] path = xyz: add
child #0 - ArcgisWorldImagery - 2
child #1 - ArcgisWorldTopo - 2
child #2 - Google Satellite - 2
child #3 - Google Terrain - 2
child #4 - OpenStreetMap - 2
child #5 - osm - 2
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item xyz: set state 0 -> 2
level item : XYZ Tiles
src/gui/qgsbrowsertreeview.cpp: 72: (restoreState) [1ms] mExpandPaths =
favorites: xyz: arcgisfeatureserver:
src/core/qgsbrowsermodel.cpp: 318: (findPath) [0ms] Arrived favorites:
src/core/qgsbrowsermodel.cpp: 318: (findPath) [0ms] Arrived xyz:
src/gui/qgsbrowsertreeview.cpp: 120: (expandTree) [0ms] itemPath =
favorites:
src/gui/qgsbrowsertreeview.cpp: 120: (expandTree) [0ms] itemPath = xyz:
src/core/qgsdataitem.cpp: 299: (childrenCreated) [10ms] path = DB2:
children.size() = 0
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = DB2:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item DB2: set state 1 -> 2
src/core/qgsbrowsermodel.cpp: 428: (itemStateChanged) [0ms] item DB2:
state changed 1 -> 2
src/core/qgsbrowsermodel.cpp: 415: (itemDataChanged) [0ms] Entered
src/core/qgsbrowsermodel.cpp: 415: (itemDataChanged) [1ms] Entered
src/core/qgsdataitem.cpp: 299: (childrenCreated) [0ms] path = mssql:
children.size() = 0
src/core/qgsdataitem.cpp: 327: (populate) [0ms] mPath = mssql:
src/core/qgsdataitem.cpp: 560: (setState) [0ms] item mssql: set state 1 -> 2
src/core/qgsbrowsermodel.cpp: 428: (itemStateChanged) [0ms] item mssql:
src/core/qgsruntimeprofiler.cpp: 54: (end) [16ms] PROFILE:
qgisapp/startup/Show main window - 0.065
Warning: Duplicate shortcut registered: About
/home/richard/bin/qgis/master/debug/lib/libqgis_core.so.3.3.0(QgsLogger::warning(QString
const&)+0x75)[0x7fb358864cdf]
/home/richard/bin/qgis/master/debug/lib/libqgis_gui.so.3.3.0(QgsShortcutsManager::registerAction(QAction*,
QString const&)+0x1bc)[0x7fb35aca3a52]
/home/richard/bin/qgis/master/debug/lib/libqgis_gui.so.3.3.0(QgsShortcutsManager::registerAllChildActions(QObject*,
bool)+0x257)[0x7fb35aca3403]
/home/richard/bin/qgis/master/debug/lib/libqgis_gui.so.3.3.0(QgsShortcutsManager::registerAllChildren(QObject*,
bool)+0x2c)[0x7fb35aca3192]
QFlags<Qt::WindowType>)+0x76d4)[0x7fb35b5b68fc]
src/core/qgsmessagelog.cpp: 27: (logMessage) [19ms] 2018-07-03T12:07:01
Qt[1] Duplicate shortcut registered: About
src/core/qgsproviderregistry.cpp: 482: (function) [9ms] Library name is
src/core/qgsproviderregistry.cpp: 482: (function) [0ms] Library name is
src/core/qgsproviderregistry.cpp: 482: (function) [1ms] Library name is
src/providers/wms/qgstilescalewidget.cpp: 120: (showTileScale) [0ms]
canvas:56025dd81270 [theMapCanvas]
src/core/qgsmapsettings.cpp: 536: (fullExtent) [10174ms] Layer count: 0
src/core/geometry/qgsrectangle.cpp: 145: (toString) [0ms] Extents : Empty
src/core/qgsmapsettings.cpp: 580: (fullExtent) [0ms] Full extent: Empty
src/gui/qgsmapcanvas.cpp: 481: (refresh) [2ms] CANVAS refresh - invalid
src/app/qgisapp.cpp: 9310: (projectCrsChanged) [0ms]
QgisApp::setupConnections -1- :
QgsProject::instance()->crs().description[WGS 84]ellipsoid[WGS84]
src/core/qgsscalecalculator.cpp: 40: (setMapUnits) [0ms] Map units set to 6
src/gui/qgsmapcanvas.cpp: 392: (setDestinationCrs) [0ms] refreshing
after destination CRS changed
src/core/qgsdistancearea.cpp: 820: (convertLengthMeasurement) [0ms]
Converted length of 0 <unknown> to 0 meters
src/core/qgsscalecalculator.cpp: 46: (mapUnits) [0ms] Map units returned
as 6
Converted length of 0 degrees to 0 meters
as 6
Converted area of 0 square degrees to 0 square meters
as 6
src/core/qgsellipsoidutils.cpp: 149: (ellipsoidParameters) [1ms]
setEllipsoid: a=6.37814e+6, b=6.35675e+6, 1/f=298.257
src/core/qgscoordinatereferencesystem.cpp: 911: (getRecord) [2ms]
Multiple records found in srs.db
src/core/qgscoordinatereferencesystem.cpp: 959: (getRecord) [1ms] failed
:  select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84
+no_defs' order by deprecated
src/core/qgscoordinatereferencesystem.cpp: 911: (getRecord) [4ms]
:  SELECT * FROM tbl_srs WHERE ' '||parameters||' ' LIKE '%
+proj=longlat %' AND ' '||parameters||' ' LIKE '% +ellps=WGS84 %' AND '
'||parameters||' ' LIKE '% +no_defs %' order by deprecated
src/core/qgscoordinatereferencesystem.cpp: 466: (loadFromDatabase) [3ms]
load CRS from
srs_id is 3239
src/gui/qgsmaptool.cpp: 91: (activate) [0ms] Cursor has been set
qgisapp/startup/New project - 0.017
src/app/qgisapp.cpp: 1357: (QgisApp) [0ms] PROFILE TIMES
src/app/qgisapp.cpp: 1358: (QgisApp) [0ms] PROFILE TIMES TOTAL - 0.504
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - User profile manager - 0
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Setting up
UI - 0.053
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Checking
database - 0.025
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Creating
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Building
style sheet - 0.004
map canvas - 0.001
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Welcome
page - 0.003
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Message
bar - 0
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/User input
dock - 0
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Layer tree
- 0.001
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Undo dock
- 0.002
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Advanced
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Stats dock
- 0.011
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Bookmarks
widget - 0.004
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Snapping
utils - 0
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Create
menus - 0.011
actions - 0
action group - 0
src/app/qgisapp.cpp: 1366: (QgisApp) [1ms]  - qgisapp/startup/Toolbars -
0.009
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Status bar
- 0.006
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Init Layer
tree view - 0.005
overview - 0
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Create map
tips - 0
decorations - 0.001
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Read
settings - 0.028
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Update
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Legend
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Initialize
3D support - 0
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Plugin
manager - 0.045
Style dock - 0.004
dialog - 0.004
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Restore
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Populate
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/Show main
window - 0.065
src/app/qgisapp.cpp: 1366: (QgisApp) [0ms]  - qgisapp/startup/New
project - 0.017
src/core/qgsscalecalculator.cpp: 129: (calculateGeographicDistance)
[0ms] Distance across map extent (m): 774097
src/core/qgsscalecalculator.cpp: 86: (calculate) [0ms] scale =
2.98543e+7 conversionFactor = 39.3701
src/core/qgsmapsettings.cpp: 208: (updateDerived) [0ms] Map units per
pixel (x,y) : 0.02040816326530612, 0.07142857142857142
src/core/qgsmapsettings.cpp: 209: (updateDerived) [0ms] Pixmap
dimensions (x,y) : 98, 28
src/core/qgsmapsettings.cpp: 210: (updateDerived) [0ms] Extent
dimensions (x,y) : 2, 2
-1.0000000000000000,-1.0000000000000000 :
1.0000000000000000,1.0000000000000000
src/core/qgsmapsettings.cpp: 211: (updateDerived) [0ms]
src/core/qgsmapsettings.cpp: 212: (updateDerived) [0ms] Adjusted map
units per pixel (x,y) : 0.07142857142857142, 0.07142857142857142
src/core/qgsmapsettings.cpp: 213: (updateDerived) [0ms] Recalced pixmap
src/core/qgsmapsettings.cpp: 214: (updateDerived) [0ms] Scale (assuming
meters as map units) = 1:29854290.59624353423714638
src/core/qgsmapsettings.cpp: 215: (updateDerived) [1ms] Rotation: 0 degrees
src/core/qgscoordinatetransform_p.cpp: 210: (initialize) [1050ms]
Source/Dest CRS not equal, shortcircuit is not set.
More information about the QGIS-Developer mailing list
