[QGIS-Developer] how to improve the resolution of a png image
SILVIA GAMERO
gamerinsky at gmail.com
Thu Jul 5 09:50:10 PDT 2018
Hello everyone,
I need your help.
I have generated an image from a wms, i did it with this code, is a transparent
background image and generates the pgw at the same time. The
background of the image is transparent, because I need to place it on
another layer, the problem is that when making the assembly it looks
choppy and can not be seen clearly
I have also tried this even with the composer of impressions and the
same thing happens.
The loaded layer is a wms.
I'd appreciate your help,
regards,
def run(self):
dpi = 400
map_settings = iface.mapCanvas().mapSettings()
c = QgsComposition(map_settings)
dpmm = dpi / 25.4
width = int(dpmm * c.paperWidth())
height = int(dpmm * c.paperHeight())
print dpi
print width, height
# set page background to transparent
transparent_fill = QgsFillSymbolV2.createSimple({'outline_style':
'no', 'style': 'no'})
c.setPageStyleSymbol(transparent_fill)
# add a map to the composition
x, y = 0, 0
w, h = c.paperWidth(), c.paperHeight()
composerMap = QgsComposerMap(c, x, y, w, h)
composerMap.setBackgroundEnabled(False)
c.addItem(composerMap)
# con este codigo obtengo las ccoordenadas del composer
composemapextent = composerMap.extent()
xmin = composemapextent.xMinimum()
xmax = composemapextent.xMaximum()
ymin = composemapextent.yMinimum()
ymax = composemapextent.yMaximum()
# create output image and initialize it
image = QImage(QSize(width, height), QImage.Format_ARGB32)
image.setDotsPerMeterX(dpmm * 1000)
image.setDotsPerMeterY(dpmm * 1000)
image.fill(Qt.transparent)
print "generando imagen"
imagePainter = QPainter(image)
c.setPlotStyle(QgsComposition.Print)
c.renderPage(imagePainter, 0)
imagePainter.end()
# self.iface.mapCanvas().saveAsImage('C:\\temp\\output.png', None, 'png')
image.save('C:\\temp\\output.png', 'png')
# Line 1: Image spacing in the X direction
print "generando pgw....."
# xmin-0, ymin-1, xmax-2, ymax-3
# resl_x = abs(extent[3] - extent[1]) / data.shape[0]
resl_x = abs(xmax - xmin) / width
# Line 2 and 3 are zero! We don't want to rotate the image
# Line 4: Image spacing in the Y direction (negative)
resl_y = abs(ymax - ymin) / height * (-1)
# Line 5: Upper-left corner coordinate in X
lonO = xmin
# Line 6: Upper-right corner coordinate in Y
latN = ymax
# Format the text, one parameter per line
navigation = '{}\n{}\n{}\n{}\n{}\n{}'.format(resl_x, 0, 0, resl_y,
lonO, latN)
print "archivo de navegacion"
# Write the file with the same file name as the image, and the ".pgw" extent
open('c:\\temp\\output' + '.pgw', 'w').write(navigation)
iface.addRasterLayer('c:/temp/output.png', 'output')
