[QGIS-Developer] External python package dependency in plugins
shiva reddy
kotishiva at gmail.com
Mon Jul 9 03:38:46 PDT 2018
Finally I found following solution, which works in both windows and mac:
import subprocess
try:
subprocess.call(['python3', '-m', 'pip', 'install','pyxform'])
from pyxform.builder import create_survey_element_from_dict
print('package is installed after python3')
except:
'install','pyxform','--user'])
print ("after python3 --user call")
try:
except:
print('not able to install pyxform, install mannually')
- First 'subprocess.call' works in Mac without permission issue.
- Second 'subprocess.call' works in windows without permission issue.
Can anybody tries this code in ubuntu/linux and verify.
Thanks
If somebody can test this in other platform, I would be very glad.
Thanks & Regards
Shiva Reddy K.
Scientist/Engineer 'SD'
Indian Institute of Remote Sensing,
Indian Space Research Organisation
Department of Space
4-Kalidas Road
Dehradun
mobile: 8791806093
On Sun, Jul 8, 2018 at 4:20 PM Luke Pinner <lukepinnerau at gmail.com> wrote:
> My mistake. Importing pip is not supported and this functionality has been
> removed in pip>=10
> https://pip.pypa.io/en/latest/user_guide/#using-pip-from-your-program
> On Sun., 8 Jul. 2018, 16:28 Luke Pinner, <lukepinnerau at gmail.com> wrote:
>> Rather than using a subprocess and needing to figure out which pip/python
>> etc., have you tried importing and using the pip module directly? Something
>> like:
>> import sys
>> try:
>> import matplotlib
>> except:
>> import pip pip.main(['install', 'matplotlib']) import matplotlib
>> Luke
>> On Sun., 8 Jul. 2018, 15:42 Axel Andersson, <axel.n.c.andersson at gmail.com>
>> wrote:
>>> Hi,
>>> I added this to my code just 3 days ago :)
>>> import sys
>>> try:
>>> import matplotlib
>>> except:
>>> import subprocess
>>> print('installing matplotlib')
>>> subprocess.call([sys.exec_prefix + '/python', "-m", 'pip', 'install', 'matplotlib'])
>>> import matplotlib
>>> print('installation completed')
>>> I dont know if it is a better or worse solution, I've only tested it on
>>> a Windows machine with the standalone version and the osgeo4w installation.
>>> I tried calling sys.executable first, instead of sys.exec_prefix +
>>> '/python', which resulted in a new qgis window started :)
>>> Axel
>>> On 7 July 2018 at 14:23, Richard Duivenvoorde <rdmailings at duif.net>
>>> wrote:
>>>> On 07/07/2018 01:26 PM, shiva reddy wrote:
>>>> > Thanks,
>>>> > In OS X following works:
>>>> > subprocess.call(['pip3','install','pyxform'])
>>>> > Does same works works for Ubuntu/linux also?
>>>> > for windows, I am assuming 'python' refers to python 3 inside QGIS3.
>>>> Yep:
>>>> import subprocess
>>>> subprocess.call(['pip3','install','pyxform','--user'])
>>>> works too.
>>>> But as said, not sure if all distro's call the python3 pip: pip3 (and/or
>>>> python3). I still would be afraid to force a specific version of a
>>>> module, as I would be afraid to override some excisting one.
>>>> I do like your solution though, the libs end up in my user site-packages
>>>> dir:
>>>> /home/richard/.local/lib/python3.5/site-packages
>>>> Ah: http://zetcode.com/lang/python/introspection/
>>>> >>> import sys
>>>> >>> sys.executable
>>>> '/usr/bin/python3'
>>>> gives you your actual python exe...
>>>> I wonder if you can create an venv from within QGIS in the subprocess
>>>> way.
>>>> Mmm, this works (from within QGIS):
>>>> >>> import sys
>>>> >>> py_exe = sys.executable
>>>> >>> venv_path =
>>>> '/home/richard/.local/share/QGIS/QGIS3/profiles/default/venv'
>>>> >>> subprocess.call([py_exe,'-m','venv', venv_path])
>>>> Had to install python3-venv though:
>>>> sudo apt-get install python3-venv
>>>> sourcing it does not work with me:
>>>> >>> subprocess.call(['source', venv_path+'/bin/activate'])
>>>> FileNotFoundError: [Errno 2] No such file or directory: 'source'
>>>> Now somebody with more knowledge of the different python-path/lib-dir's
>>>> should come in, to tell us if this is usable after activating that
>>>> venv...
>>>> Not sure if this would work with the already running python interpreter
>>>> in QGIS...
>>>> Idea's?
>>>> Regards,
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180709/b83cb83c/attachment-0001.html>
